IHC M Fuel Pump
this thread has 8 replies and has been viewed 2903 times
Old 10-11-2007, 08:38:35 PM
lister d lister d is offline
Default IHC M Fuel Pump
Hi, I have just taken off the fuel pump on my 1919 IHC M 1 1/2 HP.
It is complete but very dirty. Is there anyhing I should look out for? Hints and tips please. Has anybody got a parts diagram for the pump?
Thank you, Stephen
Old 10-12-2007, 07:36:37 AM
Tom Martin Tom Martin is offline
Default Re: IHC M Fuel Pump
I think yours will be a cast iron pump, if original, and they are pretty simple. There are two check balls in the pump- a 1/4" one in the bottom of the barrel and one in the outlet. Yours will probably have the outlet ball in a special brass fitting screwed into the upper hole in the side of the pump. I don't recall the size of the outlet ball but its either 5/16" or 3/8". The later style of pump has the outlet check ball in the pump body under the angled fitting. Check ball seats should be lapped for a good seal. The pump plunger should not be appreciably worn or the pump will leak around the packing. The body of the pump has an enlarged tapered section in the top of the bore for packing, and a sleeve that is tapered on the bottom to compress the packing, with a seat on the top for a spring that goes around the plunger to put pressure on the packing. Some people advocate using soaped mop strings for packing, but I prefer to use the graphited material that is designed for packing, and I have had no leakage problems yet. When oiling the engine I put a shot of oil on the plunger at the top of the pump to help prevent wear of the packing.
Old 09-11-2011, 06:13:18 PM
mjw9mm mjw9mm is offline
Tom,i have a 1922-24 imc 3hp. The fuel pump is white metal with the outlet to the mixer at a 45 degree angle. The plunger came out fine but i can't tell if there is a removeable bushing below it. It seams like it is cast in.I did get the packing out from behind it. Any ideas on how to get it out,its been soaking in kerosean for four days. MJW
Old 09-11-2011, 07:33:48 PM
Tom Gosciminski Tom Gosciminski is offline
There is no bushing in the pump, ( it only has the piston, the spring, the packing gland, the packing, and the 2 check balls )
Old 09-11-2011, 09:29:09 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
he may mean the ring that pushes against the packing is still stuck in at the top of the pump .tom
Old 09-11-2011, 10:14:33 PM
The ring that pushes against the packing is the packing gland. Tom
Old 09-12-2011, 01:24:20 PM
Tom , what's the best way to get the cup,or gland out? MJW
Old 09-12-2011, 01:31:18 PM
Most of the time the ring breaks when trying to remove it, ( it is only made of pot metal ) I just turn out a new one on the lathe.
Old 09-12-2011, 07:05:16 PM
mikesautosvc mikesautosvc is offline
Ive been trying to get an M pump goin myself and ordered another from hit and miss when I saw your post about the smaller check ball in the pump ,that got it goin ,now I'll have a pump for my older M
Onan 4.0BGE-1R/26109C Fuel delivery issue? Pump? Also confusion as to fuel pump part. deno Onan Generators 24 05-31-2019 02:30:12 PM
Wisconsin TF Fuel Pump Won't Prime (or Pump) Mr. Martensite Wisconsin Engines 13 02-24-2018 10:57:05 PM
Converting LK fuel pump to lawn mower pump Hummer Onan Generators 8 08-17-2016 04:05:07 PM
L634 Fuel Line Fitting Type Between Fuel Filter and Pump? Birken Vogt Onan Generators 4 08-22-2015 06:38:07 AM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
