Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag 92 compression
this thread has 3 replies and has been viewed 3463 times
Old 11-15-2007, 10:33:54 PM
Frank Timmermeier Frank Timmermeier is offline
Default Maytag 92 compression
I have a mo 92 made in 1935 how much compression (psi) should it have. what was the compression from factory?
Old 11-15-2007, 10:44:25 PM
Default Re: 92 compression
If you try to use a compression tester, you will be lucky to get 50-60 PSI out of it. You are better using the 'bounce method. ith a little oil on the rings, kick the engine smartly. As it stops, it should bounce several times on compression. If it just mushes thru, or does not bounce back, dis-assemble, and check for stuck/worn rings, and or cylinder wear, and remedy as nescessary.
Old 11-17-2007, 10:33:54 AM
Tom S's Avatar
Tom S Tom S is offline
Default Re: Maytag 92 compression
Maytag literature from 1934 indicates "about 40 pounds per square inch".
Old 12-30-2018, 08:04:40 AM
NorCalEngines NorCalEngines is offline
I got 45 psi on my rebuild.
Compression question on motors with easy spin compression release oncewaslost1982 Small Air Cooled Gasoline Engines 7 08-04-2016 07:42:59 PM
mac 1-51 compression tomolson Chain Saw Collectors 1 02-18-2016 01:36:10 AM
Maytag 92 cyl. compression Jonesey Maytag Engines and Collectibles 17 06-25-2015 07:49:56 PM
Maytag 72D compression test? KeithW Maytag Engines and Collectibles 10 07-12-2005 02:16:31 PM
IHC M 1 1/2 hp compression TomFG Hit & Miss Gas Engine Discussion 15 06-02-2005 03:19:14 AM
