70 KW Onan - How big of propane tank required
this thread has 6 replies and has been viewed 3434 times
Old 04-24-2008, 11:57:59 AM
richard.bessey richard.bessey is offline
Default 70 KW Onan - How big of propane tank required
All,
We have a newly aquired 70 KW Onan genset with a ford 460 on it, currently setup for propane, we plan to change it to Natural Gas eventually.
Anyway, as a temporary fix I was looking at getting a propane tank so we can get the genset up and running since its going to take us a bit before we have natural gas ready.
I know we have to used a good sized tank for this since the engine requires so much fuel, it will frost the tank if its not big enough.
How big of tank do we need? Will a 100 lb (20 gallon) be enough, or do we need to go bigger? Could I hook up a dozen 5 Gal tanks?
Regards,
Richard Besseh
Old 04-24-2008, 02:10:27 PM
Default Re: 70 KW Onan - How big of propane tank required
70kW will demand around a million BTU/hr or 400 cubic feet of 2500 BTU/Cu ft LPG/hr. I would get with the local LPG folks and see if they can supply a tank and size it and the regulator for that demand. The tank size will depend on above ground/in ground, lowest outdoor temperature etc. Line size will depend on the length of the run from tank to generator. Frequently a first stage regulator is used to bring the pressure down to maybe 10psi to get the vapor to the building through a smaller line than otherwise would be required if you have just the one regulator at the tank to drop the pressure to the normal use pressure.
I would guess around a 500 gallon would be the minimum and that wouldn't probably do in the winter.
Old 04-24-2008, 07:53:20 PM
K D Redd K D Redd is offline
At 70 degrees F a full 100 lb/20 gallon tank can supply 300,000 BTU's per hour. Half Full 167,000 BTU's per hour. At 40 degrees F full will provide 214,000 BTU's/HR. Half full at 40 degrees F 125,000 BTU's/HR. If you are going to use it any length of time on LP I would set a MINIMUM 500 gallon tank, A 1000 gallon would be better.
Kent
Old 04-24-2008, 10:01:09 PM
John A John A is offline
Up in your neck of the woods, I would not install anything less than a 1000 gallon tank.
Last 460 I connected used 2 - 1000 gallon tanks, and after 2 hours of operation had a frostline on both tanks.
John
Old 04-25-2008, 12:14:47 PM
On a big engine like that if there is ANY way you can feed it with LIQUID LP, depending on the safety regulations, you would not need as much tankage.
Kent
Old 04-25-2008, 11:53:09 PM
Jeffw5555 Jeffw5555 is offline
I agree; you should go with liquid feed. It's not hard to do; just really need an Impco Model E vaporizer/regulator.
Then you could run it on any sized tank. Keep in mind it will burn 4-8 gallons per hour depending on load.
I've got my 75.0 ENT running on liquid. I have a 500 gallon tank, but only because I want enough for a couple days operation.
Old 04-28-2008, 11:48:09 AM
Thanks guys, not news I wanted to hear but that info is exactly what I was after.
Thanks again!
Cutting the bottom off a propane tank? Brickman Welding Shop 57 03-02-2013 11:04:33 AM
Onan CCK help required Ben Clarke Onan Generators 14 06-27-2007 08:38:51 AM
Old red Onan generator help required. PhilipP Onan Generators 8 07-21-2005 03:06:46 PM
Propane tank/air pressure ihorse Antique Engine Archives 7 06-29-2004 11:16:06 PM
