Starting my first restoration project
this thread has 6 replies and has been viewed 2090 times
Old 06-27-2008, 02:31:43 PM
theo b theo b is offline
Default Starting my first restoration project
I am about to begin restoring a FB 1-1/2 hp Gas engine. I would like to get the whole thing cleaned up by sandblasting it. Any suggestions before I start like what should or should not be blasted, what type of blast material, etc. I will be disassembling the unit completely. Any helpful internet links would be appreciated as well.
Old 06-27-2008, 02:41:09 PM
Ray Cardoza's Avatar
Default Re: starting my first restoration project
DONT blast the bearing sets unless you plan on replacing them. dont get the crankshaft either where the connecting rod meets the throws. just watch what youre blasting.
Old 06-27-2008, 02:41:23 PM
Harry's Avatar
Default Re: Starting my first restoration project
You can start here: http://www.old-engine.com/abrasive.shtml but the answer may be a pressure washer. Or in my case, back with my first engine, a trip on the trailer to the car wash.
(See our Terms of Service)
Old 06-27-2008, 02:46:21 PM
Harry's Avatar
Get yourself plenty of masking tape and use two or three layers of it in the appropriate places. I also stuff all holes with paper towels before bead blasting.
Don't overlook the electrolysis methods found on this site.
Old 06-27-2008, 07:58:05 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
Theo,
Regarding disassembly, lots of folks suggest it is best to NOT remove the flywheels from the crankshaft unless there is a good reason to do so such as replacing a gear, straightening a bent shaft, etc. as this can lead to potential problems later on.
There have been several very good suggestions already given but you might be interested in taking a look at:
http://www.oldengine.org/members/levans/fm3hp/
which is a series of pictures and comments I posted a few years ago of a 3 hp Fairbanks Morse Z restoration. I used a power wire brush instead of sandblasting but you might pick up some ideas of tools and techniques that might help.
Regards,
Larry Evans
Old 06-28-2008, 01:39:54 AM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
Take plenty of reference pictures before, during, and afteralong with notes.
Old 06-28-2008, 02:16:31 AM
Ray Freeman Ray Freeman is offline
I've had good results using Bicarb Soda for blasting. Its not hard on the cast iron like garnet and any that does get where it shouldn't dissolves on contact with oil or water.
Restoration Project Stover 2HP KA Path Hit & Miss Gas Engine Discussion 26 09-01-2008 02:30:23 PM
Starting major steam project Lee Werth Steam Stationary Engines, Traction Engines 14 04-24-2008 08:31:55 AM
First Briggs&Stratton Restoration Project Updates Hit and Miss kid Small Air Cooled Gasoline Engines 7 02-13-2008 05:50:23 PM
Onan DJE Restoration Project Jonathan Onan Generators 69 01-15-2007 12:08:41 AM
DJE Restoration Project Jonathan Onan Generators 14 10-26-2005 04:18:48 PM
