Classic Old Engine Photos
this thread has 644 replies and has been viewed 152738 times
Old 02-01-2018, 05:09:55 PM
Friedrich W. Busch Friedrich W. Busch is offline
Default Re: Classic Old Engine Photos
Look for Karl Kaelble, Backnang, Suevia, Germany. Type R 1903 or later variations. They built everything possible self propelled such as stone crushers, saws, mills. As I mentioned already, the mill in the picture is certainly of German origin.
Old 02-02-2018, 09:25:57 AM
Kaelble R type from 1903, shortly later ioe and ohv variants were offered. Cam drive with governor, trip mechanism for low tension ignition, cylinder drain look at least similar. Photo courtesy of Klaus Schulz-Kalau.
The Following 12 Users Say Thank You to Friedrich W. Busch For This Post:
  #563
Old 02-02-2018, 09:06:20 PM
Mike Monnier's Avatar
Hoarder
USDA tweeted this photo yesterday of what appears to be an IHC LB engine powering a sprayer. Following is the photo caption: "Farmers spray raspberry bushes planted on the contour of a farm near Danville, Ohio circa 1939"
Old 02-03-2018, 03:18:04 PM
Marcel P's Avatar
Marcel P Marcel P is online now
A couple of pictures from the Wafflard factory in Liège, Belgium. The last is of my two engines. The one on the right was found with some 15 or so identical engines in a small building where the last engine builder of the family made his engines. The older one was found in a shipwreck.
Marcel
ID:	302153   Click image for larger version
ID:	302154   Click image for larger version
ID:	302155   Click image for larger version
Old 02-03-2018, 07:57:57 PM
Wayne Grenning's Avatar
Wayne Grenning Wayne Grenning is offline
This isn't from a gas engine but an interesting 18" diameter crank shaft failure. Can only imagine what collateral damage might have happened when this let go.
Old 02-03-2018, 10:22:58 PM
That looks like the crank from our 100 HP De La Vergne SI engine.
Old 02-04-2018, 09:33:57 AM
typak typak is offline
A few more, first what I think is a Bentall? mainly because there was a Bentall agent in the area at the time, next a POW camp with Japanese prisoners using a Blackstone to cut wood, next a Hornsby gas engine at the Manning river dairy co-op, this pic I have used in another thread but don't believe I have used it in this one?? what looks like a Premier? engine at a Murray river pumping station.
ID:	302240   Click image for larger version
ID:	302241   Click image for larger version
ID:	302242   Click image for larger version
Old 02-05-2018, 02:09:27 PM
Its amazing how many factory photos survive. Here is one of a gasoline fueled hot tube vertical Charter.
Old 02-05-2018, 11:48:15 PM
This photo was posted by the late Chan Mason probably 15 - 20 years ago. It is of a large air blast Snow diesel that I believe (when taken) was still located at its original pumping house in Bradford, Pa . I think it may be the same engine that is next to the 600 HP Snow at Coolspring.
Old 02-06-2018, 07:47:53 AM
He is an interesting photo of an Otto with local history. The story that goes with it is as follows: Before leaving the Otto Factory in Philadelphia, records indicate it made 37 1/4 HP on their test stand. It was built in 1897 and installed at a foundry in Buffalo NY where it ran for one year and "experienced a catastrophic failure" and ejected the piston and connecting rod. The engine was removed from service, new parts installed and the collateral damage to the engine frame repaired. It was resold to Roger and Hemphill, a machine tool company, in Alfred New York where it operated a central line shaft powering planers, grinders and other typical shop equipment. This photo was taken in 1902 at the Alfred location. Engine is stated as 36 HP 11 1/4" cylinder dia x 18" stroke with 70 1/2" diameter flywheels. The engine can be seen outfitted with test equipment as they were trying to figure out why it was under performing.
Old 02-06-2018, 10:06:00 AM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Wayne this is the 200 HP Snow at Coolspring.
The Following 8 Users Say Thank You to Keven Withers For This Post:
  #572
Old 02-09-2018, 09:58:53 PM
Sad Iron's Avatar
Sad Iron Sad Iron is offline
Dad found this in his Natural Gas Service book by Samuel Wyer
They appear to be twin tandem Snows
J
Old 02-11-2018, 01:37:02 AM
Peter Short Peter Short is offline
Sad Iron,
Thanks for that photo and the book reference. I had a look for a pdf copy and found three. Strangely all three showed another scene. Also twin tandem engines in a natural gas compressing station.
I don't think they are the same type however. The engines in your photo look to have a "belt" around the middle of each cylinder. I have read that some US engines had two-piece castings for the water jacket, however I assumed it was a horizontal part line so the cylinder itself could be accessed (not sure).
BTW, I noticed that these very large Snow engines generally seem to have their valve gear on the side of the engine. I found a photo of a Westinghouse with similar layout, but the other makes of large gas engines seem to have their valves above and below the cylinder.
Name:	Natural Gas by Samuel S Wyer 1918 04.jpg
The Following 5 Users Say Thank You to Peter Short For This Post:
  #574
Old 02-11-2018, 12:58:51 PM
Len Spoelman Len Spoelman is offline
OLDS "Plow Engine" (Tractor) 1910, Greenville, MI. Note mounted plow. First picture from company literature.
ID:	302879   Click image for larger version
Name:	OLDS TRACTOR -John Banks, Greenville, MI 1910 a.jpg
ID:	302880   Click image for larger version
Name:	OLDS Tractor RPPC John Banks b.jpg
ID:	302881   Click image for larger version
Name:	OLDS Tractor RPPC John Banks c.jpg
The Following 7 Users Say Thank You to Len Spoelman For This Post:
  #575
Old 02-11-2018, 01:07:22 PM
More OLDS tractor from previous post. Last 2 from Adams Husker literature. Adams Husker made the carts for Olds engines. Ignore dates on my pictures.
Name:	OLDS Tractor RPPC John Banks d.jpg
ID:	302883   Click image for larger version
Name:	OLDS Tractor RPPC John Banks e.jpg
ID:	302884   Click image for larger version
ID:	302885   Click image for larger version
The Following 5 Users Say Thank You to Len Spoelman For This Post:
  #576
Old 02-11-2018, 02:36:29 PM
Pictures from "Olds Gas Power Photo Album" Maybe prototype tractors?
ID:	302899   Click image for larger version
ID:	302900   Click image for larger version
ID:	302901   Click image for larger version
  #577
Old 02-11-2018, 02:45:24 PM
Pictures from "Olds Gas Power Photo Album". Olds 4 cylinder horizontal engine? Pictures of Olds engine with corn husker.
ID:	302903   Click image for larger version
ID:	302904   Click image for larger version
ID:	302905   Click image for larger version
The Following 10 Users Say Thank You to Len Spoelman For This Post:
  #578
Old 02-11-2018, 02:53:53 PM
Pictures from "Olds Gas Power Photo Album". Other special built rigs. Last one is Olds type G engines. Sign on wall says OLDS Gas Engine Works, American Suction Gas Producer Co, affiliated with OLDS.
ID:	302907   Click image for larger version
ID:	302908   Click image for larger version
ID:	302909   Click image for larger version
  #579
Old 02-11-2018, 03:08:29 PM
More pictures from "Olds Gas Power Photo Album". OLDS (?) sideshaft engines in the factory?
ID:	302911   Click image for larger version
ID:	302912   Click image for larger version
ID:	302913   Click image for larger version
Old 02-11-2018, 05:20:25 PM
More pictures from "Olds Gas Power Photo Album". Large sideshaft under construction. Type G engines.
ID:	302938   Click image for larger version
ID:	302939   Click image for larger version
ID:	302940   Click image for larger version
The Following 11 Users Say Thank You to Len Spoelman For This Post:
Clarendon Classic pics Patrick M Livingstone Hit & Miss Gas Engine Discussion 0 09-21-2008 09:57:35 PM
Classic car show Sawyer-Massey 11-22 Antique Autos and Trucks 0 08-28-2008 06:43:51 PM
Anyone get Classic Tractor Mag? (British) Colin Antique Farm Tractors 0 02-02-2008 03:26:08 PM
Classic Yacht Maqazine Ernie D Antique Marine Engines and Outboard Motors 0 07-08-2007 07:39:47 PM
