Another find on Craig's List, Briggs B & PB
this thread has 16 replies and has been viewed 2283 times
Old 03-01-2009, 08:12:03 PM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Photo Another find on Craig's List, Briggs B & PB
I went today and picked up a Briggs B and an early PB..
The B has a carb included but the PB is without of coarse
Where is the serial number on the early PB's w/o tags.
Thanks, Randy
ID:	49628   Click image for larger version
ID:	49629   Click image for larger version
He who dies with the most STUFF wins!
The Following 4 Users Say Thank You to Randy Hart For This Post:
Old 03-01-2009, 08:30:25 PM
Jonathan Widelo's Avatar
Default Re: Another find on C.List, B & PB
Randy,
My 1924 Briggs PB's serial Number is stamped on the boss on the block near where the oil filler is just like a Model P engine would be. This engine should also have a tin oil pan. Nice finds !
The Following User Says Thank You to Jonathan Widelo For This Post:
Old 03-01-2009, 09:00:36 PM
Motormowers's Avatar
Way to go Randy!
The Following User Says Thank You to Motormowers For This Post:
Old 03-01-2009, 09:28:29 PM
Junkologist's Avatar
Lucky dog! How did I miss those????
Mike
SmokStak member #146
Old 03-01-2009, 10:54:07 PM
Bob Kurtz Bob Kurtz is offline
Very nice!! Great finds.
The Following User Says Thank You to Bob Kurtz For This Post:
Old 03-01-2009, 10:58:48 PM
Travis's Avatar
Travis Travis is offline
nice hand crank B cant wait till spring to work on mine way to go man
The Following User Says Thank You to Travis For This Post:
Old 03-02-2009, 12:01:18 AM
Randy Hart's Avatar
I went out with a light and found the raised pad ( exhaust end, shroud side ) where a number would be and nothing is stamped in it.. It also has a cast iron pan / sump.
I can never rule out what may have taken place in years past as far as swapping parts.. Perhaps better light and a closer look will give me a better idea.
* Mike it came from the Columbia Station area.
Old 03-02-2009, 12:09:00 AM
Sky
If you need a place to store those.....Call me
Old 03-02-2009, 07:12:18 PM
[QUOTE=* Mike it came from the Columbia Station area.[/QUOTE]
You should have stopped in! You were 10 minutes from my house. I recall seeing an ad for a Briggs B in Columbia Station around 1/22. Was the guy's name Paul? I emailed him and decided not to check it out. Guess I screwed up...
Mike
Old 03-02-2009, 08:40:08 PM
Randy Hart's Avatar
That would have been him.. Geeeez if I had thought about it I would have come over.. Oh well.. next time I see a 1/2 hp New Holland for 50.00 up that way I'll call before I head home.
Old 03-02-2009, 09:05:02 PM
I hope I find that $50 1/2 hp New Holland before you do!
Mike
Old 03-02-2009, 09:12:33 PM
mschreiber mschreiber is offline
nice find, any chance you might part out the b? i'm sure needing a handle start shroud for one.
Old 03-03-2009, 12:26:48 AM
Randy Hart's Avatar
I don't think I'll be parting it out.. I have a Lindsay with a B engine that may need changed out
Old 03-05-2009, 12:32:24 AM
Randy Hart's Avatar
I got into the PB a little tonight and it looks pretty good over all.. I found no ser. numbers so I'm leaning towards a put together way back engine.. The flywheel is newer ( and very nice shape) and has an updated condensor. The mag plate looks great the coil is clean and throws a big fat spark... It has compression but I think the exhaust valve needs lapped in a little. I guess my next step will be to build a stand and start trying out some of the pb carbs I've collected and find a runner.. There are no tag holes in the shroud and no numbers to go by... not sure where I'll end up with this before it's all over
Old 03-05-2009, 12:54:41 AM
rusty iron's Avatar
rusty iron rusty iron is offline
If the crankshaft has right hand threads for the flywheel nut then it was made before serial number 22974. They switched to left hand thread crankshafts after that. Did you remove the piston? If so are there 2 or 3 rings?
Old 03-05-2009, 09:09:46 AM
Randy Hart's Avatar
Thank you rusty iron, it has left hand threads on the flywheel nut.. I didn't remove the piston.. I think after i lap the valve in a little it should fire up.. It's looking even more like someone did some fixing years ago with a much older shroud..
I'm by no means a PB expert.. the throttle in the intake has me a little puzzled.. were those on the much older units only or can these have a throttle and be newer ?
Thanks, Randy
Old 03-05-2009, 11:22:04 AM
rusty iron's Avatar
Default Re: Another find on Craig's List, Briggs B & PB
From what i have seen they mixed and matched elbows throughout the entire production run except for the very early engines equipped with Basco carburetors. According to the literature i have, the elbow with the throttle valve assembly was "used on engines with carburetors without throttle valve assembly" but it does not say if it was used on early or late models. My Q model has the throttle valve assembly in the elbow and the carburetor is wide open, not even a choke valve, runs like a top.
The Following User Says Thank You to rusty iron For This Post:
Briggs serial number list Horse Power at 511 Small Air Cooled Gasoline Engines 20 07-20-2017 01:32:54 AM
Spreading the Good News....CRAIG's 56! Beth V Steam Stationary Engines, Traction Engines 19 10-04-2007 11:53:13 PM
Briggs 5S find Kman Small Air Cooled Gasoline Engines 2 05-31-2007 07:07:51 PM
Parts List for briggs Marshall Jagger Small Air Cooled Gasoline Engines 3 03-14-2006 06:16:15 AM
where can i find old sales list lej peterson Antique Engine Archives 0 03-20-2002 07:45:20 AM
