Briggs F block problems
this thread has 16 replies and has been viewed 1832 times
Old 03-21-2009, 09:09:18 AM
Bob Kurtz Bob Kurtz is offline
Default Briggs F block problems
Hi
just picked up a Briggs F block with piston and crank. Well someone fooled with the piston pin and never put back the retainers ,you guessed it the pin rubbed the cylinder wall and scored it big time. question can the cylinder be bored out and sleeved? any suggestions?
Old 03-21-2009, 09:36:11 AM
K D Redd K D Redd is offline
Default Re: Briggs F block problems
Yes, unless the groove is VERY deep.
Kent
Old 03-21-2009, 09:49:05 AM
Mike in NC's Avatar
How deep are the scores? You should be able to have it sleaved. I am not sure if spray welding would work on a cylinder or not, but you could look in to that also.
SmokStak Member #28
Old 03-21-2009, 11:32:37 AM
Mike
It's pretty deep .010 you put a ring down in the groove ,with a flashlight you can easily see light through it. it is quite a rare block otherwise in perfect cond.
Old 03-21-2009, 12:38:42 PM
Mike in NC's Avatar
That block should be able to be bored. You might be able to find a piston with the right dia. and correct piston pin height. I am not sure if any other F-series piston will work. But that might be an option for you.
SmokStak Member #28
The Following 2 Users Say Thank You to Mike in NC For This Post:
Old 03-21-2009, 12:48:38 PM
bart price bart price is offline
Bob your best bet is to have it sleeved i have had good luck with sleeves . Just make sure you take it to a good machine shop
Old 03-21-2009, 01:13:32 PM
A sleeve might be the ticket oversize pistons are far and few these days
Old 03-21-2009, 01:35:44 PM
Sky
Better off just to sleave it. The actual oversized pistons for the F's are practically non-existant, today. Sleaving doesnt seem to be much. Atleast not here. I had my 4 digit sleaved @ $150 Small price to pay considering what those F series have a capability of bringing these days.
Old 03-21-2009, 04:24:53 PM
Mark97303 Mark97303 is offline
Smile Re: Briggs F block problems
Hey, I just wanted to share a few thoughts. The score marks do not run the whole length of the cylinder.The score marks are in 2 places on oppisite sides of the cylinder. The cylinder is in much better shape than if it had had water on top of the piston half way down for years and years. This engine may get run a few times a year for a short length of time at a time.(most likely not under load)The score marks are not going to effect the whole power stroke.(might loose some compression) It might blow a little oil.This is an 80 year old engine. A new tight engine is sometimes harder to start. Than a broken in one. There is not alot of extra meat in the block if you sleeve it. With that said you could end up with a nice running very desirable collectable engine wth just a good hone and new rings.
If you wanted to use a new piston I have heard of people having good results with an alum piston out of an A (oversized more available) With that done and the cosmetics done again good running engine. And if it than blows a little oil tell yourself that the rings are not broken in yet.
Last but not least hit and miss guys sometimes use JB Weld in the grooves in the cylinder and than hone it smooth than put in new rings and old piston.
And the object is to restore it to what makes you happy,you do not have to defend your decision to me or anyone. Try these or anyone of these to find out what works to your satisfaction. My 2 cents Mark
The Following 2 Users Say Thank You to Mark97303 For This Post:
Old 03-21-2009, 10:50:51 PM
Sky
Hey Bob
Here are the pictures of the F series block i had sleaved. Turned out nicely. Never mind the crack you may see in the pics. The crack in my case was due to the cylinder plug in the block but is very tiny and doesnt effect anything. Have it sleaved and fitted to .004 piston clearance and you'll have good positive results as the outcome.
ID:	50802   Click image for larger version
ID:	50803   Click image for larger version
The Following 2 Users Say Thank You to For This Post:
Old 03-21-2009, 11:36:35 PM
Sky,
Great pictures ,Great engine! Thats the route i'm gonna go. Is the sleeve .004 bigger after the piston is miked? the piston I plan on using is a single ring -the orig. it miked up within spec.although the piston pin is a little out of round. or I can go with a 3 ring piston out of an FI thats perfect. now I just have to find a good machine shop.
Hey make sure you post pictures in progress as you build your FH. Thanks again for the pictures.
Old 03-22-2009, 10:18:48 AM
Mark97303: as far as "hit and miss guys sometimes use JB Weld in the grooves in the cylinder" I seem to remember that the JB Weld was used on the area behind the piston and wasn't in the combustion chamber. While JB Weld is wonderful stuff I don't think it would hold up in the fire and heat of the combustion chamber.
Old 03-22-2009, 10:30:19 AM
Mike in NC's Avatar
A friend has used JB Weld in the combustion chamber of a heavyweight Rumely Oil-Pull and it worked great.
SmokStak Member #28
Old 03-22-2009, 10:35:45 AM
Arlie Levy Arlie Levy is offline
How about switching blocks. I am sure they are out there. Arlie
Old 03-22-2009, 11:29:02 AM
Mike in NC's Avatar
Almost ANY model F block would be worth saving. They are not too common.
SmokStak Member #28
Old 03-22-2009, 02:06:21 PM
Sky
Originally Posted by Bob Kurtz View Post
Sky,
The sleave is usually smaller then the piston after it's pressed in. Thats why afterwords it needs to be honed to fit the piston and then a finish hone fallows with 220. If it's a good machine shop they'll know what to do. Just tell'em you want what you have sleaved and .004 clearance for the piston. You may have a choice between an iron sleave or steel sleave i dont know becouse i forgot to ask when i had my engine done so i got stuck with a steel sleave but everything is still A.O.K Just find the best piston you can and Git-R-Done
Old 03-22-2009, 03:28:44 PM
grega's Avatar
grega grega is offline
now then whats the serial # i might be able to cast some parts for you and give you dimentions for others if you plan to restore it
-Greg
Briggs and Stratton Aluminum Block? Bernie Niemeyer Small Air Cooled Gasoline Engines 2 02-22-2018 09:57:30 AM
Odd Briggs Fh type block James Wallace Small Air Cooled Gasoline Engines 3 06-05-2008 10:52:59 PM
Welding Briggs Aluminum Block KidDynamo Small Air Cooled Gasoline Engines 8 06-29-2007 09:20:16 AM
BRIGGS & STRATTON DIAMOND BLOCK Peter McGuire Small Air Cooled Gasoline Engines 1 10-02-2005 10:02:42 AM
Catch block problems Greg Dills Antique Engine Archives 4 11-19-2003 12:48:22 AM
