Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
1 HP upright Maytag information and photos
this thread has 47 replies and has been viewed 52323 times
Old 01-03-2016, 07:46:08 PM
Kevin Weis Kevin Weis is offline
Default Re: 1 HP upright Maytag information and photos
Jim, nice stove leg. The pin to pin is not actually offset, the webbing between the two is not symmetrical creating the offset. The diagram from Maytag cannot be posted as it is copyrighted by the above mentioned publication. Hopefully some one can provide a casting needing machined or a used one. Would think there would be enough of a need to make worth for someone to cast several to sell.
Kevin
Old 01-03-2016, 08:12:43 PM
Axtion Jim S Axtion Jim S is offline
Kevin. Thanks for the reply, I do not want anyone to infringe on the copyright, just need to have some one do up their own scale drawing and email it to me. Then I will make a pattern and practically give them away to a needy person. As I understand copyright, as long its not used for personal gain, no issue. To darn many rules in this old world, cant we all just get along and have fun with this old stuff. IM DONE.
Old 01-10-2016, 09:24:42 PM
Jim, I'll try and do a drawing to scale and email it to you in a week or so. I's not rocket science but just the time to get to it.
Regards, Kevin
Old 01-12-2016, 04:41:22 PM
Smile Re: 1 HP upright Maytag information and photos
Thank you Kevin for your time and consideration,I look forward to your email.
Cheers Jim
Old 02-12-2016, 02:33:02 AM
Van Norman Van Norman is offline
Jim, nice picture of your project. How are you coming with the connecting rod? I would be willing to take the rod out of my 1 HP and cast one from it if you still need one.
I hope your grandson can help with restoring it. Those would be memories he would certainly enjoy for many years.
Old 03-03-2016, 12:45:48 PM
Thank you for the offer, but Bob Gail sent me one of his spare rods. I`m in the process now of making a drawing and a cad to mill the rods from air craft grade aluminum, they should last about 3 hundred years. And all of the spares my wife can use the for xmas tree ornaments.
Old 10-31-2016, 03:29:24 PM
It`s been a hecktic summer, with work and attending shows and all.but I found time to do a CAD and mill up 6 con rods from 5051 aluminum. The next process will be to true up the crank pin. The pin side of the counter weight protrudes out from the face 0.250, and 0.875 out from the center of the crank. Therefore a shaft grinder will need to have a clearance slot cut into the side face to clear the counter weight.I thought perhaps to design a rotary mill devise to drop onto the pin, but then we have a finish problem. If any one has a better process, I`d like to learn. Jim
Old 08-30-2017, 08:34:09 PM
Doodle E Do Doodle E Do is offline
Don't know if I'm in the right place even, it's my first post, lol. Looking for the spring for the bottom wringer for an old Maytag model #C2L.
Need Photos of Upright Stovers Farmall Hit & Miss Gas Engine Discussion 5 04-01-2008 11:49:30 PM
Maytag Upright 1hp With Mag - need help Mike Grivna Maytag Engines and Collectibles 7 11-07-2007 11:20:07 PM
maytag upright information David Heggie Maytag Engines and Collectibles 0 06-01-2006 08:18:27 PM
Information on an upright Samson Roger D. Green Hit & Miss Gas Engine Discussion 0 08-22-2005 10:29:25 AM
Maytag Upright Help Brad Franken Antique Engine Archives 0 05-31-2003 10:07:56 AM
