Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
NGK Plugs and Maytag
this thread has 4 replies and has been viewed 1480 times
Old 07-12-2009, 09:19:56 AM
Walter Neumann jr Walter Neumann jr is offline
Default NGK Plugs and Maytag
there is somebody on ebay right now advertizing/selling ngk spark plugs for two cyl 72 maytag.claimes hotter its a hotter plug,works with weak ignitions, less chance to fowl.does any body know the plug number,how about other brands and numbers.
Old 07-12-2009, 10:35:29 AM
Danny J Danny J is offline
Default Re: ngk and maytag
Walter my brother is running NGK plug #B2LM on one of his Maytag twins. The other is running on MotorCraft plug #AL7C.
He is also using Champion #J19LM.
He is very shortly getting an original set of Maytag plugs for a twin, that will probably go into his cutaway twin.
Hopefully this helps.
Danny J
The Following User Says Thank You to Danny J For This Post:
Old 07-13-2009, 03:01:48 PM
Mark Shulaw Mark Shulaw is offline
Hi Walter,
As long as the plug is the proper heat range for the engine no matter the brand it should be ok to use. If you have a weak??? igniton theres nothing (as a rule) that any plug is going to do to help more than one or the other and give satisfactory service. Weak spark is Weak spark. The proper size plug is the proper size. Its just advertising rhetoric on the sellers part.
The most important thing to do to get good spark is make sure all ignition components are in proper working order. As a rule weak spark is due to bad coils, dirty points, bad condensers, bad wires and so on.
Now that said if you have a engine that has good spark already and its having plug fouling problems there are things you can do with plugs to marginally help like hotter heat ranges. But this is only stop gap measures to put off with dealing with whats fouling the plugs. Mark
The Following User Says Thank You to Mark Shulaw For This Post:
Old 07-13-2009, 10:10:00 PM
Default Re: NGK Plugs and Maytag
i jus picked up some twins on the weekend,they need work.im hoping to make two out of three.just doin research firsrt before i start.i probly wont get at them for a while to much goin on
Old 07-14-2009, 06:17:15 PM
Good luck with them, if you need any help hollar. Mark
New Maytag plugs TheToolman Maytag Engines and Collectibles 5 02-28-2008 06:58:22 PM
Maytag plugs Brickman Maytag Engines and Collectibles 4 10-23-2005 12:54:50 AM
Maytag twin, what plugs? Jim Sherman Antique Engine Archives 31 03-23-2004 08:37:49 PM
Maytag 72 D Spark Plugs Papa Maytag Antique Engine Archives 14 12-13-2003 02:53:13 PM
Maytag 72 Plugs Ken Antique Engine Archives 9 09-10-2002 09:09:34 AM
