Resealing a cork float?
this thread has 5 replies and has been viewed 2756 times
Old 07-27-2009, 06:44:10 AM
Peter Ruffle's Avatar
Peter Ruffle Peter Ruffle is offline
Default Resealing a cork float?
I have a Briggs cork float that has lost it's "float" can they be dried out and resealed and if so with what in light of the ethanol in gas? This one looks like it has been sealed once before, but is lifting now.
thanks
Peter
Old 07-27-2009, 08:49:59 AM
mike kennedy mike kennedy is offline
Default Re: Resealing a cork float?
Try SEALALL...at your hardware store
The Following User Says Thank You to mike kennedy For This Post:
Old 07-27-2009, 10:27:36 AM
FarmallJeff's Avatar
FarmallJeff FarmallJeff is offline
Try a hobby shop and get model airplain DPOE clear it works grate and the gas dont bother it.
Jeff
The Following User Says Thank You to FarmallJeff For This Post:
Old 07-27-2009, 04:56:48 PM
Junkologist's Avatar
I have dipped cork floats in gas tank sealer with no problems.
Mike
SmokStak member #146
Old 07-27-2009, 05:03:36 PM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
Hey Mike, you beat me to it, works great.
[I]My Photos
Old 07-27-2009, 05:10:45 PM
Thanks guys, I'll try the tank sealer when I get it cleaned off and dried out.
Peter
Cork Carburetor Float mike kennedy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 07-07-2009 12:06:22 AM
Cork Gasket for FM ZD Cover shoptek Hit & Miss Gas Engine Discussion 2 03-18-2009 04:31:10 PM
cork float larry harding Antique Engine Archives 3 07-28-2004 08:30:17 PM
sealing a cork float Kelly Antique Engine Archives 5 07-25-2001 01:40:05 AM
Cork Carb Float Kid Dynamo Antique Engine Archives 7 12-18-2000 08:12:29 PM
