Engine cleaning, preserve original paint
this thread has 10 replies and has been viewed 2017 times
Old 11-05-2009, 01:27:51 AM
Walt Roys Walt Roys is offline
In Memory OF
Default Engine cleaning, preserve original paint
My newest toy, a vaughn drag saw, has a heavy layer of rust and grease. I find under this is a pretty good original paint job. What is the best way to clean this engine without taking off the original paint? Can you use electrolysis?
Thanks for the input >
Walt
Old 11-05-2009, 07:46:08 AM
Matt McGivney Matt McGivney is offline
Default Re: Engine cleaning, preserve original paint
kero, kero, kero. i tried use simple green and all it did was smear the grease. i then used kero and a parts brush. then when to a car wash and degrease it and wash it.
The Following User Says Thank You to Matt McGivney For This Post:
Old 11-05-2009, 08:07:17 AM
Peter Peter is offline
I use mineral spirits (real mineral spirits) paint thinner. Kero can be hard to find these days, I may try diesel in my space heater this winter.
The Following User Says Thank You to Peter For This Post:
Old 11-05-2009, 09:30:08 AM
In Memory OF
Thanks peter. By the way I use diesel in my space heater all the time. Caution though, it puts a lot of water vapor in the air. Watch for a light coat of rust on stuff. Table saw, lathe jointer and so forth. Oil everything down. Thanks for the cleaning info.
Walt
Old 11-05-2009, 11:23:55 AM
Sky
Keep in mind electrolysis removes everything. Paint too. Not something you want on a presurve job.
Old 11-05-2009, 01:51:02 PM
Rod Fielder Rod Fielder is offline
i've been using kerosine for years. works great. be careful going to the local car wash and hosing it off. a lot of car washes are still hooked to the storm sewer systems, and all of the kerosine and grease will end up in the streams and rivers.
The Following 2 Users Say Thank You to Rod Fielder For This Post:
Old 11-05-2009, 03:24:11 PM
Elden DuRand's Avatar
Now, add a little "Gunk" concentrate to that kerosene (paraffin) and you've got a really good grease cutter and it's also easy on the paint. Just follow instructions.
Available at about any auto parts store.
Take care - Elden
Old 11-05-2009, 04:11:44 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
menards and northern tool places actualy carry kero
Old 11-05-2009, 08:21:29 PM
Mike Monnier's Avatar
Hoarder
So does Lowe's, but it's about triple to quadruple the price per gallon at the local gas station. If you can't get your hands on kerosene, diesel probably would work about as well and would tend to leave more of an oily film to make that original paint shine.
Old 11-05-2009, 11:11:25 PM
In Memory OF
Hey sky, I thot that was true of electrolysis but had forgotten.
Thanks,
Walt
Old 11-08-2009, 08:50:35 PM
Matt1931's Avatar
Matt1931 Matt1931 is offline
I use go jo it works on your hands I just rub it on let it sit awile and hose it off
How to preserve old engine paint? Kevin Woodruff Paint Shop 16 02-03-2006 10:31:01 AM
Original Frick paint DrewL Steam Stationary Engines, Traction Engines 2 01-20-2006 09:45:54 PM
Anyone use ATF on original Paint? Frank B Paint Shop 11 01-14-2005 07:36:43 PM
Saving Original Paint Greg L. Antique Engine Archives 10 01-21-2004 12:53:30 AM
What do you do to preserve old paint on wood? Ron Weber Antique Engine Archives 4 11-20-2002 01:38:19 AM
