Briggs FC
this thread has 16 replies and has been viewed 1582 times
Old 11-15-2009, 10:22:56 PM
Bob Kurtz Bob Kurtz is offline
Default Briggs FC
Here are a few pictures of a Briggs FC I just finished restoring.
ID:	67218   Click image for larger version
The Following 9 Users Say Thank You to Bob Kurtz For This Post:
Old 11-15-2009, 10:30:02 PM
Default Re: Briggs FC
One more picture of the seial number
Old 11-15-2009, 11:28:16 PM
Junkologist's Avatar
Absolutely gorgeous, Bob!
Mike
SmokStak member #146
Old 11-16-2009, 01:08:04 AM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Angry Re: Briggs FC
I think Tony the Tiger said it best, THERE GRRRREAT!!!!!!
You have a great collection and do great work!!! Did you get a video of it running yet?
Dennis
The Following User Says Thank You to Dennis Wyatt For This Post:
Old 11-16-2009, 06:41:09 AM
Thanks Mike, and Dennis, I will work on a video soon,want to wait for the paint to set for a while.
Bob
Old 11-16-2009, 08:27:58 AM
Motormowers's Avatar
Bob that looks incredible! What a great job. I cant wait to get mine running, hopefully this week. The rings should be in from Starbolt soon. I still need to resolder the tin work on the trough. Hope you post a vid on the tube of it running. My vid of my other FC on the tube was from a Helio phone and is blurry. I need to buy a video camera. lol
The Following User Says Thank You to Motormowers For This Post:
Old 11-16-2009, 09:22:30 AM
RLee's Avatar
RLee RLee is offline
Looks Great! Thanks for the Pics!
The Following User Says Thank You to RLee For This Post:
Old 11-16-2009, 09:39:24 PM
Thanks for all the great comments! I know the engine looks very silver but as I was stripping the black off I noticed it was all silver so I decided to keep it that way.
Old 11-17-2009, 12:50:08 AM
Many of my FC,FE,and my FB engines still have whats left of their silver paint so I think it was a common color.
Old 11-17-2009, 03:55:12 PM
Tom Schaech Tom Schaech is offline
Hi Bob!!
Beautiful engine job! I notice the rocker arm appears to be bronze---is that correct? I've never cleaned mine, but it may be as well. I know my FB is bronze.
Great work, my friend!
Tom
The Following User Says Thank You to Tom Schaech For This Post:
Old 11-17-2009, 07:21:44 PM
Thanks Tom, I appreciate that! As far as I know the bronze rocker was used on the early FCs, then it changed to the cast iron rockers later in the series, yours may be nickel plated.
Bob
Old 11-17-2009, 07:54:01 PM
grega's Avatar
grega grega is offline
verry nice, i sure wish i had one!
-Greg
The Following User Says Thank You to grega For This Post:
Old 11-17-2009, 08:47:44 PM
Thanks Grega,I'll trade ya for the F LOL
Old 11-19-2009, 07:19:52 PM
Bob I got the FC running today but it only runs about 30 seconds before the plug gets so washed with oil it stalls. I pulled the head and noticed how much oil is being pushed up due to the worn piston. I knew it was bad but took a shot anyways, the new rings cant make up for it. So now Im on the hunt for an FC/FE piston and rod assy. I was able to fix the trough problem by etching the tin with muriatic acid to get the alum coating off so the solder would stick and it worked fine. Oh well.
Old 11-19-2009, 08:26:47 PM
Jonathan Widelo's Avatar
Is the bore really wore or just the piston ? My FB block needs to be .020 oversized since it was real wore, when I find an oversized piston I am going to have the block bored out.
Good Luck on your Search John !
~ Jonathan
Old 11-19-2009, 10:47:06 PM
Jon the cylinder looks great, in fact it doesnt even have a ridge so Im thinking its prob the piston. Its also got a pretty good wrist pin knock. If I can even find an FE piston and rod assy I would be in. I may try to swap a later piston and rod and try using the cap off the FC rod and play with some shims. John.
Old 11-20-2009, 09:25:35 AM
Talking Re: Briggs FC
John:
I'm not in front of the parts list now---the FC piston has an oil control groove instead of a ring, correct? I'll look---slim chance I may have one.
Tom
Original Briggs pump?+1943 briggs NPR6 41Briggs Small Air Cooled Gasoline Engines 4 12-30-2009 11:21:28 AM
