IHC fuel pump
this thread has 6 replies and has been viewed 2060 times
Old 10-16-2002, 07:34:06 PM
George Eddy
Default IHC fuel pump
I just found a fuel pump its brass and has a part number of GA6775, I think that its IHC any help would be great thanks, great site Harry!!!
Old 10-17-2002, 06:37:13 AM
John Hammink
Default Re: IHC fuel pump
George are you sure the number is right? I have all the parts nummbers except for the Moguls, if the number is right it could be a Mogul pump.
"Sixm"John
Old 10-17-2002, 08:20:11 AM
George Eddy
I checked the number again and it is a GA6775, It has places for 3 fuel lines on the bottom, and is a 2 bolt like famous is. ill try to get a photo posted, thanks,
Old 10-17-2002, 08:49:38 AM
Harry's Avatar
The A in the part as in the Famous GA stands for assembly. I have the complete original IHC Mogul Repair Parts catalog #2 and most of those parts appear to end in a T or TA. 6775T does not exist. The few G part numbers in it are three digit. I should get busy and have this book reprinted!
My Famous parts book reprint is missing page 144 in the IHC Vertical Engines where that GA6000 series number might be.
Old 10-17-2002, 09:36:58 AM
John Hammink
Harry here you have page 144. If you reprint that Mogul book give me a call.
"Sixm" John
Old 10-17-2002, 10:50:59 AM
Harry's Avatar
That printed just great, thanks.
Finding a print shop and the procedures to deal with them is something I've got to get acquainted with. I could scan my Mogul book and put it on a CD, but that's a time problem. It covers Kerosene and Gasoline Tank and Hopper cooled engines from 1 to 50 HP. January 1st, 1918.
Old 10-17-2002, 03:32:17 PM
Rob charles
Hi Harry, I think Starbolt has a book similar to that.it may just be the master mogul parts book though.Early 10-20 titan tractors use a brass feul pump that looks similar to the one on a larger famous.i think it only has an in and out though.Maybe thats a tractor pump for the early friction drives or the like. Rob
Onan 4.0BGE-1R/26109C Fuel delivery issue? Pump? Also confusion as to fuel pump part. deno Onan Generators 24 05-31-2019 02:30:12 PM
Wisconsin TF Fuel Pump Won't Prime (or Pump) Mr. Martensite Wisconsin Engines 13 02-24-2018 10:57:05 PM
Converting LK fuel pump to lawn mower pump Hummer Onan Generators 8 08-17-2016 04:05:07 PM
L634 Fuel Line Fitting Type Between Fuel Filter and Pump? Birken Vogt Onan Generators 4 08-22-2015 06:38:07 AM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
