Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Old brass Carburetor?
this thread has 2 replies and has been viewed 3175 times
Old 09-13-2010, 05:45:57 PM
MotorPower MotorPower is offline
Photo Old brass Carburetor?
Hello
Is this off an old inboard motor ??? And if so what motor dose it go on ??? Thank you for your Help !!!
http://s909.photobucket.com/albums/a...t=IMG_0154.jpg
http://i909.photobucket.com/albums/a...g?t=1284414301
Old 09-13-2010, 06:38:01 PM
Jeff Miley Jeff Miley is offline
Default Re: Old brass Carburetor ???
That is an old Krice carb. off a marine engine. Many of the early marine engines used Scheblers or Driblers as some like to call them (Schebler Model "D" Carbs were the most common). Other manufactuers of the time included Krice and Kingston. It appears to have an attached check valve which would indicate it came off a two cycle-two port engine. The three port engines did not need the check valve (I think I have that correct). Hope this helps. Looks like it is decent shape.
The Following User Says Thank You to Jeff Miley For This Post:
Old 09-14-2010, 12:32:54 AM
Default Re: Old brass Carburetor?
It looks like it might be from a Lockwood Ash marine engine, called a Motorgo if sold by Sear & Roebuck, judging by the manifold assembly.
Certainly, Krice carburetors were used on marine engines. I don't know if they were also used on other engine types.
The Following User Says Thank You to KidDynamo For This Post:
Help! Onan 7NHMFA26106C carburetor brass filings in gas inlet. Windmill Bob Onan Generators 4 04-27-2010 02:12:01 AM
Looking for carburetor Jean Hit & Miss Gas Engine Discussion 5 09-29-2009 08:35:46 PM
Need Carburetor help Neale Behm Hit & Miss Gas Engine Discussion 19 09-09-2008 06:37:00 AM
Carburetor Kit help egeschwill Kohler Generators 6 05-24-2008 02:11:05 AM
B&S Z Carburetor Ralph Leonard Small Air Cooled Gasoline Engines 6 07-18-2005 06:59:27 AM
