Gas tank sealer suggestions?
this thread has 16 replies and has been viewed 4409 times
Old 09-24-2010, 07:42:56 PM
Warren Eastham Warren Eastham is offline
Default Gas tank sealer suggestions?
Hello All,
I have a Delco-Light Model B-12 generator with a small sheet metal tank that leaks very slightly (pinholes, I think). The tank is very slightly rusted inside and it has baffles.
What's a good product for sealing it?
Thanks,
Warren
Old 09-24-2010, 07:54:22 PM
Dennis Wyatt's Avatar
Dennis Wyatt Dennis Wyatt is offline
Default Re: Gas tank sealer suggestions?
I have used KBS on several different tanks. Tractors and small engines. I have had very good luck with it. Good luck!
http://www.kbs-coatings.com/Tank-Sea...ds_tank_sealer
The Following User Says Thank You to Dennis Wyatt For This Post:
Old 09-24-2010, 09:24:26 PM
Joe Prindle's Avatar
Joe Prindle Joe Prindle is offline
I am really happy with the results I get from Red-Kote brand sealer, and it is available from O'Reilly auto parts for about $23 a quart.
Joe
The Following User Says Thank You to Joe Prindle For This Post:
Old 09-24-2010, 10:08:19 PM
David K David K is offline
I've had good results with Bill Hirsch Gas Tank Sealer < http://www.hirschauto.com/ >. I've used it in chainsaws & small engine gas tanks and the guy who turned me on to it used it for automotive gas tanks.
For large holes, a little JB Weld on the outside to cover the hole (let it harden) and then gas tank sealer inside.
Dave
The Following User Says Thank You to David K For This Post:
Old 09-24-2010, 10:34:07 PM
John Dunn John Dunn is offline
A motorcycle collector friend used to swear by a product / sealer named KREEM, not sure if it's still available.
The Following User Says Thank You to John Dunn For This Post:
Old 09-24-2010, 10:43:10 PM
Kris Golden Kris Golden is offline
I use and like "U.S. Tank" from the POR-15 guys. It looks like a galvanized surface when cured and works with todays ethanol fuels.
The Following User Says Thank You to Kris Golden For This Post:
Old 09-25-2010, 12:22:11 AM
ar2stp48 ar2stp48 is offline
Have used Red Kote many times on old car resto's and old engine tanks. It is very good.
The Following User Says Thank You to ar2stp48 For This Post:
Old 09-25-2010, 01:12:55 AM
Roland Hayes Roland Hayes is offline
Hi, tried them all but there is only one reliable way to seal pinholes in the bottom of a fuel tank and that is to solder a blob over the hole. I use a 75 watt electric iron and normal multicore solder, the steel takes the solder very well and its very quick and easy to do and its permanent. Hope this helps.
The Following User Says Thank You to Roland Hayes For This Post:
Old 09-25-2010, 05:11:02 AM
Rob Kuhlman Rob Kuhlman is offline
Ditto on the POR-15 product.
The Following User Says Thank You to Rob Kuhlman For This Post:
Old 09-25-2010, 07:39:00 AM
Zira Zira is offline
I bought sealer from Lee Pedersen (sponsor here) and had very good luck with it, it seems to resist the ethanol fuels better than some that I tried in the past. That said, I didn't use it to fill holes, just seal seams & keep the gas/ethanol from attacking the JB Weld that I filled the holes with.
The Following User Says Thank You to Zira For This Post:
Old 09-25-2010, 08:09:38 AM
Esteban32696 Esteban32696 is offline
" KREEM " is still around. Many antique motorcycle restorers use it. Follow directions exactly !
http://www.monsterpowersports.com/at...combo-kit.html
The Following User Says Thank You to Esteban32696 For This Post:
Old 09-25-2010, 08:58:52 PM
JeffK's Avatar
JeffK JeffK is offline
If you have a leak on your tank and you need a emergency fix I know what to do.
Rub a bar of soap on the leak.
I learned that from Gus Wilson and the Model Garage. Who remembers his young helper Stan Hicks and what about that cheapskate Silas Barnstable. [Popular Science magazine car mechanic]
Idle hands are the devils workshop
Old 09-26-2010, 04:32:45 PM
Jeffk,
Thanks, that reminds me of being shown, about 40 years ago, that Oxydol soap would seal a leak. I didn't know other soaps would work.
I'll certainly keep it in mind. As a matter of fact, I could have tried it this morning!
Thanks again,
Warren
Old 09-26-2010, 05:07:40 PM
Warren Wolf Warren Wolf is offline
Watch what you use, not all sealers are good to go with Ethanol. I use red-kote and I know it works with that.
Old 09-26-2010, 05:39:47 PM
Craig DeShong's Avatar
Craig DeShong Craig DeShong is offline
I'd reccomend you patronize a sponsor of this site,because without our sponsors we just might not have SmokStak. Like Zira, I've had excellent results with Lee Pederson's product and I won't hesitate to reccomend it.
I've found that if the pin holes are small (they really are pinholes), you can wrap some masking tape around the tank, and then treat it with tank sealant and the holes will seal; you may need to do it several times and give the sealant a few days to dry.
[I]My Photos
Old 09-27-2010, 04:54:32 AM
Thanks Craig,
Mailed my order to Lee Pedersen yesterday. I'll wrap with masking tape as you suggested.
Warren
Old 09-28-2010, 07:27:09 PM
bill chasser bill chasser is offline
I don't recommend JB Weld for tank or any fuel system related repairs. I used to think it would work on anything and have used the product for many years however, I tried to use it to repair a cracked/broke off carb flange and venturi on a M-S vh model carb. I made several attempts even after letting the epoxy cure for several days before installation the oxygenated fuel we have in CA attacked the repair eventually dissolving from the fuel while I was test running an engine. A lesson learned from the benefit of others failures ....
Tank sealer in a installed tank Gilbert_Bates Hit & Miss Gas Engine Discussion 10 07-21-2008 08:40:02 PM
Gas tank sealer Neill Hit & Miss Gas Engine Discussion 5 02-26-2007 08:56:20 AM
Gas tank sealer Ihorse Hit & Miss Gas Engine Discussion 3 12-28-2005 02:19:09 AM
Tank sealer Hal Davis Antique Engine Archives 3 07-15-2002 10:13:45 PM
Gas Tank Sealer Dale Antique Engine Archives 3 02-11-2001 11:33:24 AM
