General Engines Co. purchase
this thread has 25 replies and has been viewed 5913 times
Old 11-20-2010, 12:06:42 AM
desotonut1953 desotonut1953 is offline
Default General Engines Co. purchase
I purchased a General Engines Co. gas engine recently. Does anyone have any info. on the history of this company and info. on the engine. Missing the gas tank, but everything else looks good. Thanks for the help.
Old 11-22-2010, 05:02:04 PM
Junkologist's Avatar
Default Re: General Engines Co. purchase
There's very little info out there on these engines. They seem to be well built and run pretty good too. I believe they were built right around 1949.
Here's two that I have.
Mike
SmokStak member #146
Old 11-22-2010, 05:08:17 PM
John Newman, Jr.'s Avatar
Here is a video of one of my Generals.
My other one looks better, but this one runs better...
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 11-25-2010, 10:25:16 PM
Larry Rarus
Hello again Mike,
I too have a GE. I think the only model they ever made was a D21! Here are some pictures of my refurbishment effort.
ID:	93470   Click image for larger version
ID:	93471   Click image for larger version
ID:	93472   Click image for larger version
The Following 2 Users Say Thank You to For This Post:
Old 11-25-2010, 10:33:14 PM
Larry Rarus
Some more photos.... The short block is now assembled. I need to figure out a complete ignition system for it. The engine came with only a set of poorly deteriorated points and nothing else. I found that a B & S coil is a direct bolt-on fit. Now I have to work on the rest of it. Unfortunately I have somewhat lost interest in this particular project and it sits lonely in the loft of my garage. Also, I have an owner's manual tucked away somewhere. Maybe I could scan it and make it available on-line if anyone is interested.
ID:	93474   Click image for larger version
ID:	93475   Click image for larger version
Old 11-27-2010, 12:30:55 AM
Hi Larry,
I just got this off ebay. Everything is there, had the fan cover off and everything looks good. I'm getting a manual and repro decal from John Newman.
I put my Clintons to rest while I work on my Cub Cadet lately. Is that a Reo motor in the background in picture #4? Got one of them recently also.
How do you get your engines so clean? Do you sandblast them? I'm still trying to figure out how to get the engines cleaned up without a lot of equipment. I'm going to buy a larger air compressor in about a month. Mine currently is made from old Tecumseh Products refrigerator parts.
---------- Post added at 11:30 PM ---------- Previous post was at 11:22 PM ----------
Larry,
I was wondering about the ignition. The coil looks like a B&S. Haven't got the flywheel off yet. I can post some pictures of what the points look like when I get to this project. It may be awhile though as icefishing season is about here, and I am trying to concentrate on getting the Cub Cadet done as it is the oldest project, after the Choremaster project. I will wait on starting choremaster with Clinton in spring so the gas doesn't go bad.
BTW, I saw your complete Clinton chainsaw on the Clinton forum. BEAUTIFUL! Where did you finally find the lefthand nut you needed?
Old 11-27-2010, 10:24:25 AM
Larry Rarus
Yes, that's a Reo in the background. I have a few of them. They're great little runners.
Regarding how I get my engines so clean... It's a multi-step process. First I do a complete tear down. It's impossible to get them perfectly clean otherwise. The grease and crud of years of use always jam into the nooks and crannies. Then I have a degreasing tank ( see here: http://www.northerntool.com/shop/too...2051_200422051 ) where I soak these pieces for a few days. The final step is indeed blasting. The key to blasting is to use the correct media. I only use the silica stuff for the coarse cast iron pieces. For aluminum and stamped metal I use crushed walnut shells (no kidding). It gets the surface nice and clean without pitting.
Thanks for the compliment on the Clinton D50 Handy. I never could find a new nut for that. I don't believe they're manufactured anymore. I simply dressed the existing one as best I could. By the way, it's the one that holds the clutch onto the crankshaft.
Old 12-26-2010, 10:51:08 PM
Jack H's Avatar
Jack H Jack H is offline
Looks like a well made engine mostly made of cast iron? Funny, I have never seen one of these engines up close that I can recall...
https://sites.google.com/site/hitandmissgasengines/
Old 12-27-2010, 10:14:27 PM
Jack, even the fan shroud is cast iron. Not a stamped piece of sheet metal. Everything looks very well made.
I don't know much about the engine history, although I have googled the company and the brothers that owned the engine company. Probably another company that Briggs & Stratton sued for some minor design infringement, and put them out of business.
---------- Post added at 09:14 PM ---------- Previous post was at 09:12 PM ----------
General Engines Co., a division of Leuthesser Brothers, Franklin Park, Illinois.
Any one know anything about this company?
Old 12-27-2010, 10:39:36 PM
The only cast iron part on my General engines is the cylinder. Everything else is cast aluminum. Are you sure your shroud is cast iron? Try putting a magnet to it.
Mike
Old 12-27-2010, 10:42:40 PM
Sorry. Its cast aluminum. Unusual though I think. Everything I've ever seen was stamped sheet metal.
Old 12-27-2010, 10:51:10 PM
You'll find that sometimes when things like engines are hastily manufactured, they will be mostly made up of castings instead of stampings. It takes a lot less investment to produce castings as opposed to the presses and dies it takes to make stamped steel products. I would imagine that if the General engines would have been more successful, we'd see later engines with stamped steel shrouds, but as it stands, I think they were only made for a year or two and never really got off the ground. Seem to be good engines, though.
Mike
Old 12-29-2010, 03:04:20 AM
Make sense as you said. Have you ever compared the engine parts to B&S parts. They look very close to the same. Even the oil pump looks like an Clinton. Did they buy these from the 2 companies parts department instead of designing all of their own? When I get around to restoring this and my Clinton and B&S of similar size I will compare them. They seem like a nice engine to use on many small applications. NOt use what I will put this one on. Maybe a display cart.
Old 12-29-2010, 02:31:43 PM
GaryH GaryH is offline
Genaral may have been associated with Auburn Cord Dusenberg... see this link
http://home.roadrunner.com/~harg43/GeneralEngines.pdf
Gary
The Following User Says Thank You to GaryH For This Post:
Old 02-12-2016, 09:45:19 AM
maytag340 maytag340 is offline
I picked this one up yesterday day
ID:	246226   Click image for larger version
Old 02-12-2016, 02:27:14 PM
Update from a few years back. I will attempt to attach a PDF file from Gas Engine Magazine --May-June 1979.
General may have been associated with Auburn Cord Dusenberg.
Old 06-02-2016, 08:18:13 PM
What make is that mower? That is the first General I have seen on a piece of equipment. Nice find.
Mike
Old 06-02-2016, 09:12:53 PM
I can't remember I'll check tomorrow
The Following User Says Thank You to maytag340 For This Post:
Old 06-03-2016, 03:55:40 PM
Doug Tallman Doug Tallman is offline
You beat me to it, Mike. I was thinking the same thing.
The Following User Says Thank You to Doug Tallman For This Post:
Old 06-04-2016, 11:39:56 AM
Dick DeBuse Dick DeBuse is offline
Midget Motors appears to have picked up the factory leftovers, advertised them in their Directory. Also B&B used them in some of their Brogan Cycle scooters in the late 40s, early 50s.
General Engines John Newman, Jr. Small Air Cooled Gasoline Engines 13 01-12-2016 06:34:26 PM
General Engines Co. Junkologist Small Air Cooled Gasoline Engines 1 04-07-2010 10:33:36 PM
MDJB Purchase lijobi Onan Generators 20 04-20-2009 12:11:32 AM
My new purchase... please help jaw123 Hit & Miss Gas Engine Discussion 5 03-31-2008 08:05:29 AM
New Purchase Brian Dykstra Farm Antiques and Collectibles 4 10-04-2006 11:38:02 PM
