General Engines Co. purchase
this thread has 25 replies and has been viewed 5937 times
Old 06-06-2016, 05:22:24 PM
maytag340 maytag340 is offline
Default Re: General Engines Co. purchase
Sorry it took a couple of days to get back to y'all
Old 08-02-2016, 03:05:25 PM
Ira Ira is offline
Larry,
My name is Ira and I was glad to see that you too had a General Engine. My son found one of these in a trash dumpster and brought it home, when we got to looking at it we noticed that the cam rod had came out and the cam was out of time, so we took it all a part to reline the timing marks and discovered that there were no timing marks on anything. Did your engine have marks on the crank and cam? I seen where you had a manual for yours, does it indicate the relation between the crank and cam? If you can help me out in anyway I would sure appreciate. Thank you.
Ira
Old 10-28-2016, 09:58:30 PM
Jeff LaCrone Jeff LaCrone is offline
I wonder what the lowest serial # anyone has. Mine is serial # 1607
Old 11-01-2016, 04:15:44 PM
Junkologist's Avatar
One of mine is #1309.
Mike
SmokStak member #146
  #25
Old 08-31-2019, 06:02:46 PM
uglyblue66 uglyblue66 is online now
Well I picked up serial number 23430 Model D today.Type 21.All but the gas tank and it's bracket.Not stuck,has been painted and put on a skid of sorts.
Sadly there is some damage to the exhaust threads.I aint too good with Google but this was the ONLY link that came up when I searched for this.
Old 09-12-2019, 09:13:07 PM
Well I unbolted this engine from this skid and was going to install it on a nicer 1. I found my engine is not a "prime" example so to speak. I found a chunk gone from the shroud that the screw goes into to hold it on the engine. I found 2 fins broke off the cylinder head and it has NO compression and very little spark.
And what kind of spark plug fits it? It had 2 big washers under a common plug and it was not tight.must be a very short plug as in the electrode section.
General Engines John Newman, Jr. Small Air Cooled Gasoline Engines 13 01-12-2016 06:34:26 PM
General Engines Co. Junkologist Small Air Cooled Gasoline Engines 1 04-07-2010 10:33:36 PM
MDJB Purchase lijobi Onan Generators 20 04-20-2009 12:11:32 AM
My new purchase... please help jaw123 Hit & Miss Gas Engine Discussion 5 03-31-2008 08:05:29 AM
New Purchase Brian Dykstra Farm Antiques and Collectibles 4 10-04-2006 11:38:02 PM
