Steam Engines
Doing the most to Preserve Boilers
this thread has 0 replies and has been viewed 1122 times
Old 12-17-2010, 01:01:52 PM
Jim Conte's Avatar
Jim Conte Jim Conte is offline
Default Doing the most to Preserve Boilers
Ishadley,
Welcome to 'Stak.
We have had a lot of newcomers lately...
When you do get around to steaming your boiler, remember this;
Water is not naturally friendly to boilers.
It can be corrosively acidic or laden with minerals that cause scale.
Cold water holds dissolved gases that pit and rust steel.
Dissolved salts can also pit steel and lead to galvanic corrosion of dissimilar metals.
Uneven heating due to scale deposits and poor circulation can generate mechanical stresses far greater than the pressure of steam.
Boilers need a water pH around 10. What we call neutral water, pH around 7, is like acid to steel.
Under most circumstances, placing plain water without treatment in a boiler is doing slow and irreversable damage to that boiler.
Unfortunately, many individuals, businesses and institutions tend to ignore all the above until the damage is done.
I wish you all the best with steaming and living off the grid.
http://www.boilersaver.com/
The Following 8 Users Say Thank You to Jim Conte For This Post:
Engine cleaning, preserve original paint Walt Roys Hit & Miss Gas Engine Discussion 10 11-08-2009 08:50:35 PM
How to preserve old engine paint? Kevin Woodruff Paint Shop 16 02-03-2006 10:31:01 AM
Fwd: Boston, MA: Help Preserve the engines of the James Hefner Steam Stationary Engines, Traction Engines 0 07-21-2004 06:12:06 PM
What do you do to preserve old paint on wood? Ron Weber Antique Engine Archives 4 11-20-2002 01:38:19 AM
boilers Pete Antique Engine Archives 1 12-17-1999 12:17:11 AM
