IHC 6 Hp Famous Full Restoration
this thread has 20 replies and has been viewed 5765 times
Old 01-08-2011, 10:43:08 PM
Bob Hanauer's Avatar
Bob Hanauer Bob Hanauer is offline
Default IHC 6 Hp Famous Full Restoration
Look what showed up for a full restoration today. Serial number 543 and looks to be on original cart but it looks like it is backwards. I am in need of a fuel pump, carborator, water pump, new fuel tank and cooling screen. This should be a fun project and we will be documenting the progress of the restoration with pictures here on Harry's. Any help with finding parts will be very much appreciated.
thanks
Bob Hanaue
Harry
ID:	97434   Click image for larger version
The Following 13 Users Say Thank You to Bob Hanauer For This Post:
Old 01-08-2011, 11:45:15 PM
Skip Landis Skip Landis is offline
Default Re: 6 Hp IHC Famous
Bob, looks like it HAS the rotary water pump.
Old 01-09-2011, 11:13:48 AM
Martin Reed Martin Reed is offline
Bob,
A lot of engines were sold as saw rigs in which case the engine was put on "backwards" like yours. I suspect your engine was a saw rig outfit at one time and whoever cut the wagon down to reduce it's length. The way you can tell is the front bolster. If you could post a close up of the front axle we could tell for sure. Also, it looks as though you have some form of water pump in between the flywheels next to the engine base. Three different water pumps were used on the 6hp depending on its age. The earliest was a centrigual water pump, then they went to a piston arrangement then a gear pump. Give us the full serial number with letter prefix and we'll be able to give you an age which will give a clue as to what water pump it originally had. IHC supplied two different types of water cooling tank, also depending on age. The other parts will be a little difficult to find but a lot of guys have them or are making reproductions. Good luck and nice engine!
Old 01-09-2011, 02:31:42 PM
Justin Justin is offline
Sn. JB543, We have the original screen cooler but it is in poor shape. I also got a 2nd water pump with the engine but it is different than the one on the engine. The one on the engine is a gear pump.
Old 01-09-2011, 07:41:40 PM
Here are waterpump and front axel pictures
ID:	97532   Click image for larger version
ID:	97533   Click image for larger version
Old 01-09-2011, 08:59:17 PM
The front bolster is for the portable and not a saw rig so someone just placed the engine backwards. Again, nice project engine!
Martin
Old 01-09-2011, 10:47:05 PM
Hi , I checked the letter code in the book and JB comes up mounting engine so it may have never come on the cart. It's a 1907 so I would think that it would have had a tray cooler tank.It also has a Webster setup so that may be a retro fit added later.Sometimes a couple of neighbors had similar engines and when 1 conked out the two were assebled into 1 working unit. Still a nice project.keep us posted. Rob
Old 01-10-2011, 10:57:36 PM
Default Re: IHC 6 Hp Famous
Rob's right about the water tank, it would have had what they call a "tray" cooled tank. The only one I saw for sale was on ebay a year or so ago and it went for around 800.00 but it was an original in good shape. It's going to be expensive to make, lots of trays in the interior. I happen to like the screen cooled tanks better; spectators ask a lot of questions when they see the water going over the screen whereas with a tray cooled model you don't see any water. Your engine would have also had the centrifigual water pump which is hard to come by. I would recommend going with the gear pump. I think someone has reproduced those. Maybe Rob knows who has them. The clutch pulley would also be different, again harder to come by but there around. I have attached a photo of a JB242 I fixed up a couple of years ago.
Martin
Old 01-11-2011, 08:35:43 PM
I think Don Oberholtzer made that gear pump. He is a sponser here check with him.Rob
Old 01-18-2011, 04:16:30 PM
Got back to work on this last night and remover the engine form the cart. Looks like the cart was shortened up buy not sure. Dose any one know how long the rails should be for a portable cart? I also need a fuel pump and a carb for this engine anyone have them or castings for them? I will be taking the engine apart tonight as the head had been welded before and needs to be cleaned up and a valve job done. Then all the paint will be removed and repainted as there is none of the original paint left. Hope to post photos of the tear down tomorrow.
Old 01-20-2011, 12:06:25 AM
We started at 3pm this afternoon and with the engine completely apart by 8:30pm.
ID:	98368   Click image for larger version
ID:	98369   Click image for larger version
ID:	98370   Click image for larger version
Old 01-20-2011, 12:09:37 AM
The cart is completely disassembled, the rails where cut off 3 1/2 inches and they were turned around. This is why the engine was on backwards. This is a very easy fix.
ID:	98372   Click image for larger version
ID:	98373   Click image for larger version
ID:	98374   Click image for larger version
Old 01-20-2011, 12:11:56 AM
The head cylinder and piston went to Eric's shop so he can work with magic.
ID:	98376   Click image for larger version
ID:	98377   Click image for larger version
Old 01-20-2011, 12:14:03 AM
I beat you did not think I was that young? ha ha this is my son Ben helping with this engine
The Following User Says Thank You to Bob Hanauer For This Post:
Old 01-26-2011, 07:43:39 PM
BTurney BTurney is offline
from a secret location purportedly for an 8 HP famous and believed to be a reliable source
ID:	98858   Click image for larger version
Old 01-26-2011, 09:27:50 PM
LarrapMan's Avatar
LarrapMan LarrapMan is offline
That looks like a real good find!
We have a later 6hp Portable J2851E which I think is about 1916/18. When abouts did they add the speed control lever behind the carb and what mechanism do the earlier models have?
Thanks Joe
Old 01-26-2011, 09:38:38 PM
Bturney,
Yes that does look very much like a 8hp IHC tray cooler. Nice, so what are you waiting for...
Martin
Old 01-26-2011, 10:15:37 PM
Bryant Bryant is online now
I would like have that tank for my 8hp
Old 01-26-2011, 11:22:55 PM
Default Re: IHC 6 Hp Famous Full Restoration
Was at it again today and got the cart, base and flywheels sand blasted along with 2 gas pumps that I am also restoring. Have to go back to work on Friday so I hope to get the cart in primer tomorrow so I can paint it next weekend. That tray cooler would be cool but allready have a screen cooler and gas tank on the way from John Wanat. Photos tomorrow I hope.
Old 02-22-2013, 12:14:40 AM
Wow I cant belive its been over 2 years but it almost done! Just got all the wood done tonight. Will varnish it tomorrow. Then all thats left is exhaust and plumbing. Have it running real slow and sounds great.
ID:	158642   Click image for larger version
OLD hubcaps = Box full Esteban32696 Antique Autos and Trucks 6 09-28-2010 07:09:03 AM
15 hp IHC famous restoration Mike Buck Hit & Miss Gas Engine Discussion 0 07-08-2008 11:45:48 PM
Full choke Alan Ruschman Antique Engine Archives 6 02-26-2004 12:12:17 PM
