Mystery brass carb
this thread has 7 replies and has been viewed 2235 times
Old 07-04-2011, 09:24:04 AM
Danno Danno is offline
Default Mystery brass carb
found this one over the weekend it don't have any markings that i can see, the carb body is brass, the float bowl looks like aluminum, any ideas as to what make it is?
Thanks,
Danno
ID:	109910   Click image for larger version
ID:	109911   Click image for larger version
ID:	109914   Click image for larger version
The Following User Says Thank You to Danno For This Post:
Old 07-04-2011, 10:42:53 AM
Exclamation Re: Mystery brass carb
Looks similar to the one used on my Pacific Engineering fire pumps. They use engines built by Evenrude and Johnson, so I would bet the design is one of theirs. Your carb is missing a cover on the fuel bowl. It is held in place with the small spring steel part extending out from under the screw on the left. This cover has a hole in the center, unsealed, that the shaft on the float ectended thru, when the cover was in place. the cover centered the float, so it acted correctly, and when the exposed pin was depressed (held down), allowed the fuel to overfill the bowl. When fuel flowed out the top, you knew you had enough to prime the engine intake passage. This feature also allowed you to clear most small debris from under the fuel level needle too.
Old 07-04-2011, 05:21:23 PM
Junkologist's Avatar
Default Re: Mystery brass carb
What size intake will that clamp on to?
Mike
SmokStak member #146
Old 07-04-2011, 10:12:46 PM
Measures 7/8 id
Old 07-05-2011, 07:17:49 AM
grega's Avatar
grega grega is offline
Iv got the same carb on my briggs and stratton model P. I was just wondering about when it was made.
-Greg
"There only origionial once"
The Following User Says Thank You to grega For This Post:
Old 07-06-2011, 11:55:29 PM
-Greg
Greg
Do you know if this was original to the Briggs model P?
or who made this carb?
Old 07-07-2011, 07:57:21 AM
grega's Avatar
No it is not a briggs carb, and I have no information on it.
-Greg
Old 09-06-2011, 12:11:22 AM
Axtion Jim S Axtion Jim S is offline
Hi Dan, That carb may off TYPE 3 Massey Harris 1.2 HP the one that looks like a Fairbanks Style D. you could walk by the complete engine and mistake it for the more comon D engine.
The Following User Says Thank You to Axtion Jim S For This Post:
What is this all brass carb terry tabb Hit & Miss Gas Engine Discussion 7 11-06-2008 10:45:45 PM
Mystery Carb. Eric McKenna Hit & Miss Gas Engine Discussion 1 02-01-2005 11:47:05 PM
Brass FH Carb Stevie Mote Small Air Cooled Gasoline Engines 1 10-23-2004 02:29:17 PM
MYSTERY...Brass carb? Alex Antique Engine Archives 2 03-14-2004 09:58:20 AM
Lunkenheimer Brass Carb tim Antique Engine Archives 4 12-22-2002 06:11:12 PM
