How do i clean a water jacket?
this thread has 4 replies and has been viewed 7228 times
Old 11-08-2011, 05:34:46 PM
madmowerz madmowerz is offline
Unhappy How do i clean a water jacket?
Hey i just pulled my willies jeep engine out and started to overhaul.
The water jacket is plugged up with all sorts of crap it almost reminds me of mud!
i dont have a power washer so what would be the best thing to do here? would soaking the whole block in diesel help at all?
Old 11-08-2011, 08:32:58 PM
Heins Heins is offline
Default Re: How do i clean a water jacket?!
What you need to do is take it apart down to the bare block and take it to a machine shop and have them hot tank it.
Old 11-08-2011, 08:36:43 PM
Do what I do, load her up with a pocket full of quarters and go to the car wash and get the wand out and go to town.
---------- Post added at 08:36 PM ---------- Previous post was at 08:34 PM ----------
Should have said, load her up, take a pocket full of quarters, and go to town and wash the water jacket out.
The Following User Says Thank You to Pat Barrett For This Post:
Old 11-08-2011, 09:21:33 PM
K-Tron K-Tron is offline
I dont know how large the water jacket is on your engine, but when I went to clean out my Detroit Diesel 6V53T, I was armed with a screwdriver, a spray bottle (clorox bottle) full of diesel, and a 3000psi power washer. It is amazing how much scale and rust buildup comes flying out of the drain holes. The cylinder liners are removable on my engine, so I could get in there with a flat head screwdriver and really get to town on the rust. If you cannot borrow a power washer from a neighbor, or rent one, I would find out first what your engine block is made of aluminum or iron, and then look at different radiator cleaners and scale removal chemicals. Alternatively, hot tanking the engine works well, but can be hard to find a place around that has one.
Good luck,
Chris
Old 11-08-2011, 10:30:58 PM
vern0n's Avatar
vern0n vern0n is offline
If you do the hot tank method, expect to replace cam bearings. I usally go to the car wash with long screw driver and some stiff wire. I have seen some engines so packed with lime, I had to use a long drill to get that stuff out.
Lime in Water jacket Craig B Oil Field Engines & Related Equipment 7 11-06-2006 12:00:52 PM
Water Jacket on 4 hp Acadia Ed Welsh Antique Engine Archives 0 09-12-2002 09:11:01 PM
water jacket still clogged Ed Welsh Antique Engine Archives 1 06-24-2002 06:52:40 PM
clogged water jacket Ed Welsh Antique Engine Archives 4 06-23-2002 12:56:02 PM
rust in water jacket walter Antique Engine Archives 5 05-16-2001 12:08:42 AM
