1928 Twin Shroud Briggs and Stratton FH
this thread has 32 replies and has been viewed 8996 times
Old 11-27-2011, 10:45:48 PM
Junkologist's Avatar
Default 1928 Twin Shroud Briggs and Stratton FH
I just picked this engine up at an auction Saturday. Had it running that evening and the engine is like new in regards to wear.
Anyone know the story on these twin shroud versions? I suspect the shroud was added to serve as a guard around the spinning governor housing so laundry wouldn't get wound up in it. The pto was on the magneto side, so I assume the other side was probably somewhat exposed on the side of the washer. The added shroud could serve no other purpose that I can see.
Name:	Briggs FH twin shroud 006.jpg
Mike
SmokStak member #146
Old 11-27-2011, 11:01:01 PM
Mark97303 Mark97303 is offline
Default Re: 1928 Twin Shroud Briggs FH
Looks and sounds really nice. I am sure you will have it running the way you want soon.
The Following 2 Users Say Thank You to Mark97303 For This Post:
Old 11-27-2011, 11:03:43 PM
Nathan Grissom's Avatar
Nathan Grissom Nathan Grissom is offline
I have a twin shroud FH but it is a slant fin.
Nathan
www.nathansoldiron.blogspot.com
The Following 2 Users Say Thank You to Nathan Grissom For This Post:
Old 11-28-2011, 12:02:09 AM
oldmotors's Avatar
oldmotors oldmotors is offline
it's a briggs fi a heavy duty fh kind of like a industral briggs i have a few mowers with fi briggs on them real nice engine you have there
Old 11-28-2011, 12:25:25 AM
Dan Baalman Dan Baalman is offline
Not a FI, they had two rocker arms to actuate both intake and exaust, just a twin shroud FH
The Following User Says Thank You to Dan Baalman For This Post:
Old 11-28-2011, 12:26:50 AM
Yea kind of. The Fi had a rocker controled intake valve. And the 2 shrouds and the other carb. Could be it was the first thought that there might be a need for twin shrouds.
The Following User Says Thank You to Mark97303 For This Post:
Old 11-28-2011, 12:57:58 AM
One thing you have to realize is that there is nothing to blow air in the added shroud. This engine does not have a cast iron blower flywheel like the FI does. This engine is just your typical straight fin FH with an additional shroud.
Mike
Old 11-28-2011, 03:26:36 PM
Jim Metzger Jim Metzger is offline
Nice find. True double shroud FH's are rare even among Briggs collectors.
The Following 2 Users Say Thank You to Jim Metzger For This Post:
Old 11-28-2011, 04:07:13 PM
Dengine Dengine is offline
Very nice Engine! Great pick up! Nice job on the video,description and info.
The Following 2 Users Say Thank You to Dengine For This Post:
Old 11-28-2011, 05:28:37 PM
RLee's Avatar
RLee RLee is offline
Nice find, never seen a double shroud round fin before.
I have a double shroud slant fin like the others.
The Following 2 Users Say Thank You to RLee For This Post:
Old 11-28-2011, 06:00:26 PM
Marc P Marc P is offline
Yup, FH. The FI does have the two rockers and both flywheels have cooling fins. I have an FI listed on Engineads right now to see the difference.
By the way you have a very nice engine.
The Following User Says Thank You to Marc P For This Post:
Old 11-28-2011, 09:17:40 PM
Motormowers's Avatar
My double shroud FH is slant fin and but has the cast flywheel and drive pulley on the starter side. Other than that nothing unusual at all about it. Like Mike said I think certain washer MFG's had the engine placed below in a way that the PTO side stuck out some and the shroud offered a little safety. Just out of curiosity what are all our ser# ? I can post mine Tues eve.
---------- Post added at 08:17 PM ---------- Previous post was at 08:14 PM ----------
Marc, that was a great deal on that engine. From the looks of that coupling on the mag side it was off a Cooper mower. I have a 1928 like that.
The Following 2 Users Say Thank You to Motormowers For This Post:
Old 11-28-2011, 10:32:17 PM
Everett Hayden's Avatar
Everett Hayden Everett Hayden is offline
John,
I have a twin shroud, slant fin as well. Mine is #12202.
I was told that the round fins were the scarcer by far of the two varieties of twin shroud. I am gonna guess that a pot metal slant fin twin shroud would just about take the cake
for rarity. The drive pulley on my slant fine is a flat belt.
The Following 3 Users Say Thank You to Everett Hayden For This Post:
Old 11-29-2011, 08:09:29 PM
Tom Schaech Tom Schaech is offline
All:
A great find!! They are indeed rare; I have a round (straight) fin dual shroud FH with the pot metal carb. I got it from the original owner who said it was on a washing machine when he was a little kid; he later rescued the engine from the scrap pile and much later had it restored.
Great engine and a nice addition to the other FH's I have...
Tom
The Following 2 Users Say Thank You to Tom Schaech For This Post:
Old 12-12-2011, 06:48:36 PM
Charliechaindrive Charliechaindrive is offline
Brggs made a engine with rocker arms!?!
O_o first day nthi forum my mindsaredy been blown
That's the coolest briggs ever!
The Following User Says Thank You to Charliechaindrive For This Post:
Old 12-12-2011, 08:51:18 PM
Antiquebriggsguy Antiquebriggsguy is offline
Talking Re: 1928 Twin Shroud Briggs FH
im not a proffesional but i dont think an fh needs two blower shrouds and since you have 2 on yours and the fh i picked up last week doesnt even have 1 it will work out perfect ill take it thanks
Old 12-12-2011, 09:39:00 PM
I also have one missing a shroud, so I'll just put the extra one on it.
Mike
Old 12-15-2011, 12:50:19 PM
Scott W. Taylor Scott W. Taylor is offline
Briggs and Stratton parts book lists five different sub part blower housings for FH under master part number 69203. They are, quoting verbatim from B&S lisitng: "65362 Housing-Blower Used as a governor side flywheel gaurd" (which is what Junkologist has); "66669 Housing-Blower Hole for stop button on exhaust side. Used on some rope starter engines"; "69066 Housing-Blower Hole for stop button on carburetor side. Used on some foot starter engines"; "69083 Housing-Blower Hole for stop button on carburetor side. Used on some rope starter engines"; 69175 Housing-Blower No holes for stop button. Used on some rope starter engines" So there you go, several flavors of shroud available!
The Following 3 Users Say Thank You to Scott W. Taylor For This Post:
Old 01-29-2012, 04:59:23 PM
Jerry Sweet Jerry Sweet is offline
Default Re: 1928 Twin Shroud Briggs and Stratton FH
Yesterday I bought a centrifigul pump unit,it has a model"F1"Briggs&Stratton,S.N.11553 on it.It is direct coupled to a American-Marsh "Redi-Prime" pump and was packaged by Simons Machinery Co.of San Francisco.The unit was used by Hetch Hetchy Water and Power company of the City and County of San Francisco.It' a very nice clean unit.All the above companies are still in buisness.I would like to date this unit.Could someone tell me the year of the engine by the serial number ? Thank you,Jerry
Old 01-29-2012, 06:29:31 PM
Jerry, sounds like you have an FI engine as Briggs never made an F1. Going by your ser# the engine was made in Jan 1930. Hope this helps. Lets see some pics, sounds like a very cool piece.
1928 Briggs & Stratton FH Junkologist Small Air Cooled Gasoline Engines 4 04-06-2011 06:46:16 PM
1928 FI Briggs Original Colors For Reference Scott W. Taylor Small Air Cooled Gasoline Engines 0 01-22-2011 01:17:13 AM
Briggs Y Shroud ciggs Small Air Cooled Gasoline Engines 4 11-16-2010 01:08:09 AM
WI Briggs with Aluminum Blower Shroud Chitty Chitty Bang Bang Small Air Cooled Gasoline Engines 7 11-18-2008 03:52:51 PM
Early Briggs FH shroud K.Watkins Small Air Cooled Gasoline Engines 12 09-16-2006 05:25:40 PM
