Onan 4.0CCK-Has rope start pulley. Can it start with electricity?
this thread has 8 replies and has been viewed 3406 times
Old 11-22-2011, 09:08:10 PM
Default Onan 4.0CCK-Has rope start pulley. Can it start with electricity?
I just saw an Onan 4.0 CCK at an auction. I didn't think to get the s/n. Didn't know if it would matter for this question.
It has a large rope start pulley on the flywheel. Will this type of Onan start by powering the generator exciter or whatever with a battery like my 6.5NH?
I can go back and get the s/n data if needed.
Pete Stanaitis
Old 11-22-2011, 09:19:06 PM
Billy J Shafer's Avatar
Default Re: 4.0CCK-Has rope start pulley. Can it start with electricity?
Most likely not. It is a portable unit. But need the model and serail number to tell you.
Old 11-23-2011, 12:13:25 AM
MBB MBB is offline
It could have both. I have a 3.5 cck with a pulley and its electric start. Get the serial number to be sure.
Old 11-23-2011, 01:01:33 AM
MBB is correct. That is why we need the full model and serial number.
Old 11-23-2011, 04:29:20 PM
Patrick Patrick is offline
Default Re: Onan 4.0CCK-Has rope start pulley. Can it start with electricity?
Yep, all mine are electric start - to be honest I wouldn't like to try starting them by hand, particurly without a recoil! But the numbers tells the truth.
Billy, a quick question if I may interrupt the thread - all mine are ex Army, battery start. You can start them by the rope pulley if you have about three people to do it.
Some have a push button on the control box saying "Keep pressed for manual start", some do not. Any idea what the difference is? They all have battery leads.
Old 11-23-2011, 06:32:13 PM
Keep pressed for manual start. Will bypass the control start system. Very common on some of the old Onans. Most of them have a toggle switch. But if you leave it in manual. It can burn out the points. So on some systems they use a spring loaded switch. Also on alot of military units you will find a switch marked Combat Run. Which means it will run and if anything goes wrong it will not stop until it has destroyed itself.
Manual start means easy rope start or a large drill motor with a pulley and a belt.
Old 11-25-2011, 04:52:12 PM
Sorry for not getting full model/sn earlier.
It is:
Model: 4.0 CCK 1R 6000P (Do I have enough zeroes?)
S/N: 0971334699
I now see that is has 2 switches on the back side of the control box that is mounted above the genend. The top one says "Start"/ "Stop" and it's a center off switch as on the later NH's that I have. The other one says "Hand Crank"/Elect Start". So I guess I have answered my own question.
I don't NEED this machine. What I really need is either a 50 KW single phase or a 75 KW 3 phase 240 volt machine. But I fear that I will try to buy this one anyway. What is wrong with me?
Pete Stanaitis
Old 11-25-2011, 06:53:28 PM
Nothing wrong with you.
Old 12-18-2011, 06:50:03 PM
DrCharles DrCharles is offline
I found out today why people pay for the electric start... pulling the cord on my "new" 10.0CCKAJ 1E (s/n D920459200) is quite an exercise!
Now that my arm is quite tired, I am interested in possibly converting it to remote start also... can this be done with the generator head I have?
thanks
Charles
Briggs model M rope start clutch Dengine Small Air Cooled Gasoline Engines 10 10-14-2011 08:28:04 PM
Adapting a Maytag Mod 82 Pull Rope Start Francis Maytag Engines and Collectibles 1 03-14-2011 07:42:58 AM
Rope Start Round Head FH Briggs Junkologist Small Air Cooled Gasoline Engines 4 07-26-2009 07:02:17 PM
Briggs FH slant fin rope start Jim Sherman Small Air Cooled Gasoline Engines 9 04-07-2006 03:31:59 PM
Briggs FH rope start date? Jim Sherman Hit & Miss Gas Engine Discussion 1 01-10-2006 02:41:11 PM
