Paint Shop
Faairbanks Morse Z D color?
this thread has 2 replies and has been viewed 2394 times
Old 08-10-2011, 06:33:14 PM
ScooterBob ScooterBob is offline
Question Faairbanks Morse Z D color?
I searched here for color info, but didn't see the D engine mentioned.
Will the "Dark Hunter Green" be about the correct color for this engine too?
There are some areas of paint on the engine, but since it was bare behind the flywheel on the crankcase, I suspect the light green I see was from a quickie rattle can job.
Any help will be appreciated.
Thanks, Bob
Old 08-13-2011, 12:21:00 PM
grub54891's Avatar
grub54891 grub54891 is offline
Default Re: Faairbanks Morse Z D color?
The one I just picked up is dark green in spot's.Still have to clean it up and get it checked over before trying to start it.
Old 08-13-2011, 01:42:43 PM
If it's like mine, I'd at least suggest you pull the crank cover and check the condition inside. Mine had lots of rust on the gear teeth that I wouldn't have wanted to have in there while running.
Post #7 here...
http://www.smokstak.com/forum/showthread.php?t=93521
...has a picture of the insides when I pulled the cover.
Best of luck with it, Scooter Bob
Fairbanks Morse Z Color? ted simpson Hit & Miss Gas Engine Discussion 8 07-23-2017 09:16:09 AM
Fairbanks-Morse Paint Color Jeffrey Weldon Paint Shop 13 02-28-2010 11:56:45 AM
Fairbanks Morse 5 hp N color? Ray Gardner Hit & Miss Gas Engine Discussion 6 01-03-2009 08:32:12 PM
Fairbanks Morse Dishpan color Gregg Hart Antique Engine Archives 0 12-14-2003 02:46:17 AM
Fairbanks Morse Color chase Antique Engine Archives 4 12-22-2001 07:42:23 AM
