Unleaded Gas in a Coleman Stove
this thread has 13 replies and has been viewed 32051 times
Old 01-13-2012, 06:24:05 PM
JoeCB JoeCB is offline
Default Unleaded Gas in a Coleman Stove
Question please, Is it OK to run todays unleaded / 10% ethanal in the old Coleman appliances that were designed for just Coleman Fuel? I know that some of the new appliances are compatible with unleaded, but how about the older ones?
Joe B
Old 01-13-2012, 07:22:30 PM
OTTO-Sawyer's Avatar
Default Re: Unleaded gas in a Coleman stove
I'll go out on a limb and say I don't see any reason why not.
I'm not real familiar with how the Coleman equipment is set up, but there were enough toy/model steam engines made over the years that used Alcohol burners that I doubt 10% alcohol would be a problem in something made to run on gas.
Old 01-13-2012, 08:17:19 PM
bitsnpieces1 bitsnpieces1 is offline
The problem is in the equipment generator. It sits in or near the flame/heat producer. Liquid fuel enters the bottom and is heated and vaporized creating pressure which forces the vapor through a jet and into the burning apparatus (ring burner or filament). The problem comes when the fuel contains dissolved solids which don't vaporize and remain in the generator gradually plugging it up. So alcohol wouldn't be a problem since it would vaporize. However, other additives that are added for octane rating would be the problem since they would plug the generator. If you can find gasohol that doesn't have the other additives it should be fine. Les
The Following User Says Thank You to bitsnpieces1 For This Post:
Old 01-13-2012, 10:10:37 PM
From what I've found since seeing the question is that gas lanterns will operate on unleaded gas but not as good. Coleman now makes a dual fuel lantern that runs on either Coleman fuel (white gas or naptha) or unleaded gas. No mention is made of ethanol gas in the ad that I saw, however.
Personally I would only use Coleman fuel or naptha gas in a gas lantern or camp stove. For one thing you don't have to worry about storage life of the fuel. Another consideration in using gas containing ethanol would be the corrosion of generator parts. (Remember all those corroded carburetors on lawnmower engines etc. from another thread)
Bill
Old 01-13-2012, 11:42:17 PM
Exclamation Re: Unleaded gas in a Coleman stove
Gasoline is a lot more volatile than coleman fuel. I would not use it, especially in older equipment.
Old 01-14-2012, 02:11:25 AM
Alan Rudd's Avatar
Alan Rudd Alan Rudd is offline
I got my first Coleman lantern from my grandpa when I was 14. It still works fine today. I have four other gasoline lanterns and two Coleman two burner stoves. To this day I have never in my life bought a can of coleman fuel. I have always used regular gasoline. One time when I was camping on an island in the river I had to resort to boat gas with oil in it. Now this was back in the old days with leaded gas and a quart to six gallons mix ratio. I can tell you that it works just fine but it gives a yellowish light.
The newest lantern or stove I own is at least 30 years old. Right now I have two lanterns out in my Bounder and I will bet the homestead both will fire right up.
The Following 2 Users Say Thank You to Alan Rudd For This Post:
Old 03-27-2012, 05:41:31 PM
Email NOT Working
When I was a boy I experimented with various fuels in various stoves and lanterns. What I found was that the cook stoves don't really seem to care what fuel you use although maximum output is somewhat reduced on car gasoline. I think it is lighter fractions, i.e. lower energy per volume than white gasoline. Also an old single mantle lantern from the 1940s ran fine on car gas but one I bought from the late 60s only "fills" the mantles with fire about half way on car gas. Very inadequate light. When I bought some coleman fuel it was like looking at the sun.
I even got one of those old green single burner coleman cook stoves with the straight generator to run on Kerosene. I stuffed a wad of fiberglass insulation under the generator in the center of the burner, soaked it in kero and set it on fire. Once it was pretty well heated I opened up the main fuel and it ran fine and blue though if ran at max output if I recall it would start to overtake the vaporization capacity of the generator and get yellow tips to the flame and might even overflow with liquid fuel eventually but if turned to a lower setting would run indefinitely.
Old 11-17-2013, 07:27:02 PM
Polyhead
Joe B
unleaded gas in any coleman gear has always been a bad idea. It works, but don't expect it to work for very long. You have dies in there along with other aditives and they all end up stuck in the generator. You can only clean the generator so many times before the walls just get too thin from the brush and then the genny has a blow out. Even the ones that are "designed for it" really only tolerate it and will run longer on coleman fuel or pure naptha if you can get it.
Now if your brave, and a little bit dumb (like me) you can go ahead and re-refine the gasoline. That removes almost all of the stuff that will plug up a generator. I'll leave it to you to design your own still for this purpose.
Would I put unleaded gasoline in my northstar? Sure, I can get parts for it.
Would I put it in my handy gas plant? No, I can't get parts for it.
Old 11-18-2013, 04:02:27 PM
gootsch gootsch is online now
I agree with Polyhead.
I own many Coleman lanterns and stoves of many vintages and I use only Coleman fuel as it is just plain easier. As in easier to remember what you were using for fuel in each appliance. I have experimented with gasoline, gasoline and Coleman fuel and gasoline, Coleman fuel and kerosene. They all like Coleman fuel.
I have 2 Coleman lanterns built for kerosene. The 1944 vintage lantern will burn anything resembling kerosene just fine, fuel it up, warm it up, light it and forget it for the evening. As for the 1990 vintage lantern, I have yet to find a fuel that it likes, this lantern needs tending way too often throughout the evening.
Old 08-21-2019, 02:48:21 PM
Rodney Dawn Rodney Dawn is offline
always used regular unleaded and never had a problem. In fact I have a vintage "instant-gas" gasoline range installed (was original to the house) in full working order. Obviously I installed quality CO detectors due to carbon monoxide risk but as long as tank pressure is optimal and the generator tubes are clean (easy to do as they are rather large diameter) it has never given a problem. Granted I use regular unleaded ethanol free same as my generator, but the only issue ethanol might present is eating away at tank seals and not producing as much heat.
suitcase stoves and lanterns can be a bit harder to clean the generator tube but it still isn't too difficult, and replacements can be found for about the same price as a can of white gas so there really is no reason to use anything but regular unleaded.
(house also had "hollow wire" gasoline lighting originally but the system was in such disrepair only the front porch lighting and one basement fixture were operable. I salvaged all the components when I installed electric (generator) lighting but left the porch fixtures in place. relocated the tank to the covered porch and ran new tubing to just those fixtures as the tank itself was in great shape for its age. )
For those who don't know, hollow-wire was an early lighting system that competed with the various coal gas and acetylene gaslight systems availible in the 20's-30's. it involved piping pressurized gasoline through thin hollow tubes "wires" to fixtures which consist of a lantern-type generator and burner assembly mounted to a ceiling fixture, wall sconce, or post lamp. fuel was fed from a central tank in the basement, and while notably safer than acetylene systems, the thin nature of the tubing and avalibale toolage of the era meant the system was prone to developing leaks.
Old 08-21-2019, 03:46:40 PM
Harry's Avatar
I use Coleman fuel in my old gas engines and it works great and doesn't crap up the mixer or fuel lines if you leave it sit afterward. It's basically naphtha the same thing old engines ran on. At $7 to $8 per gallon, I don't use enough as to be a big deal although I sure wouldn't want to be using it in my car!
Coleman fuel in an IHC Famous: https://www.youtube.com/watch?v=yZzu...qH4CA&index=18
(See our Terms of Service)
The Following 2 Users Say Thank You to Harry For This Post:
Old 08-22-2019, 06:40:49 PM
During our last hurricane, I used the same gasoline I run my generators on in my coleman stove. The only thing I noticed was the black soot built up on my pots and pans fairly quickly while in use. Maybe I need to service and clean my coleman stove?
Robert
Old 08-22-2019, 09:51:54 PM
oldtractors's Avatar
Umm, the alcohol is what adds the octane. By your theory, there should be less crap in the gas that is mixed with ethanol. They don't "add" things to gas to make it compatible with ethanol. They do, however, start with 82 octane swill that isn't even a legal fuel before adding the ethanol.
Jim Evans
Old 10-20-2019, 11:55:09 PM
dkamp dkamp is online now
eMail NOT Working
Default Re: Unleaded Gas in a Coleman Stove
Octane is a hydrocarbon: C8H18.
One can add as much Ethanol (C2H6O) to a solution, it does not add Octane under ANY circumstances.
Carbohydrates interfere with the burn speed of lighter-fraction hydrocarbon fuels (hexane, pentane, septane) such that the flame speed is reduced, mimicking the slower flame speed of a fuel composed of larger hydrocarbon fractions like Octane. It is by this reasoning, that states 'allow' fuels to be 'advertised' as having a higher "Octane Rating", than without.
The difference between Coleman Fuel and common pump gasoline, is Benzene- Aside from being very carefully filtered before contanierized, Coleman Fuel's fractions are much more controlled, there's basically no Benzene... it's closest to Naptha... but breaking it down, you'll find Octane, Heptane and Pentane in it... and because of that, it will burn much cleaner in both soot, and dangerous emissions.
If you choose to run it in your lanterns or stoves, do NOT use it in enclosed areas, and realize that Benzene is a nasty carcinogen. The detergent additives that you see stations raving about... they don't go nicely with camp stoves, and as was noted on another thread- the gasoline you get out of the 'lower end' of the fuel price realm, is the recipient of test-samples and cleanup remains of diesel washouts. When my wife did sampling and testing for the local storage/distribution facility, any thing flammable and liquid to be disposed, went into the low-grade tank. Dillution is the Solution.
Unleaded Fuel John Mathieson Smokstak Down Under 2 04-12-2014 06:35:15 PM
Coleman gas vs unleaded fuel 95gts Fuels and Alternative Fuels 11 12-20-2013 07:36:36 PM
Unleaded Petrol John Mathieson Smokstak Down Under 10 12-10-2009 03:18:26 PM
Unleaded gas with or without additives bill jacobsen Hit & Miss Gas Engine Discussion 8 09-22-2007 10:04:34 PM
Unleaded Gasoline Larry Meston Antique Engine Archives 9 06-25-2000 05:46:33 PM
