Smoky Anderson engine
this thread has 4 replies and has been viewed 1309 times
Old 01-13-2012, 07:48:23 PM
robert hamilton robert hamilton is offline
Default Smoky Anderson engine
Hi all
I have a 2hp Anderson built in NZ that smokes really bad iv removed the cylinder and found that the ring gaps where in line with each other so I put them right i ran the engine for about 2 minutes and the smoking started again is there a reason the rings are rotating in the cylinder and how do I fix it as running for 2 minutes it is literally blowing oil out the exhaust
http://www.youtube.com/watch?v=Mrpz39FKMLM
Old 01-13-2012, 07:58:11 PM
Motorhead's Avatar
Motorhead Motorhead is online now
Default Re: Smoky Anderson engine
Is there a crankcase vent? Is there a "TIMED" breather valve? I worked on an old Harley Davidson 74ci flathead twin. It smoked like crazy. Ended up we didn't have the breather for the crankcase timed right.
Old 01-13-2012, 08:03:06 PM
the crank case breather it just a cast iron elbow with some holes in it bolted to the side of the crank case there is no timing needed
Old 01-13-2012, 09:58:05 PM
Motorhead's Avatar
Is the breather clear? Did you check the ring gap with only the piston ring inserted in the cylinder? Are the piston rings directional oriented in that could they be upside down?
Old 01-13-2012, 10:25:04 PM
Todd Hodges's Avatar
Todd Hodges Todd Hodges is offline
ring grooves are wore uneven letting the rings to turn go to OTTO ENGINE WORKS on sponors page and read about ring spacers I've use them on my engine with the same problem really help
The Following User Says Thank You to Todd Hodges For This Post:
Smoky Onan 15JC bobbyz72 Onan Generators 14 04-01-2011 07:03:46 AM
Smoky ChoreBoy choreboy-uk Hit & Miss Gas Engine Discussion 1 04-22-2008 05:52:36 AM
Smoky Mountain N & S LeeCox Steam Stationary Engines, Traction Engines 11 09-12-2006 04:22:18 PM
Smoky Mtn. Swap Meet KeithT Hit & Miss Gas Engine Discussion 1 05-11-2006 10:58:49 PM
Smoky Mtn engine show-swap meet May 7 KeithT Hit & Miss Gas Engine Discussion 1 05-06-2005 09:16:32 PM
