Need opinion on Onan CCK spec R
this thread has 7 replies and has been viewed 1487 times
Old 06-30-2012, 04:16:02 PM
rcowboy rcowboy is offline
Default Need opinion on Onan CCK spec R
Okay fellas,
I ran across a 4.0 CCK-3cr spec R made in August of 74 and was hesitant to pick it up. I was able to talk him down to $200 but even then I wasn't quite sure. I want to see what ya'll think.
Problem #1: The control board on top was pretty much toast. I think it was resistor R13 was burnt in half. This is what really pushed me away. I know alot of ya'll replace these boards with relays and such, but just wasn't sure at the time.
Here's my thinking on this, if I have to dump $300 or $400 in this, it's not really worth it to me. I'd have more in it than its worth, and I want to replace my CCK-1R with a 240V machine.
Problem#2: They were using a replacement fuel pump that was attached to the OEM. Another words, the new fuel pump was pushing through the old one.
This is not a really big deal, but still another turn away for me.
Problem#3: It seemed to be running slow.
Again, probably no big deal. Just needs a governor adjustment or a carb cleaning. It did misfire a couple of times.
Problem #4: Missing a few nic nacs here and there. Rubber feet pads etc.
Problem #5: While it was running, the dude pulled the battery off.
Argh!! Eventhough it wasn't my machine yet I wanted to
Your opinions please
David
Old 06-30-2012, 04:28:22 PM
MBB MBB is offline
Default Re: Need opinion on CCK spec R
Your better off with the relays. An easy fix. The other things are minor. Dont like the fact he disconnected the battery while running. It does produce voltage? Try for a little lower. If it doesnt produce voltage forget it.
The Following User Says Thank You to MBB For This Post:
Old 06-30-2012, 04:42:48 PM
I don't know exactly what problems are caused when the battery is removed.
Does it mess the exciter up, or the 12V side? He's done it twice that I know of.
He said it produced power, and I trusted him. The reason I trusted him was because he said it ran, and it did. If I decide to go back, I will check for power.
I couldn't get him off the $200, he said it was worth that in scrap to him, so thats going to be his lowest price.
David
Old 06-30-2012, 05:06:44 PM
lokay5's Avatar
lokay5 lokay5 is offline
Personally, in the condition it's in, I think $200 is too much. For another $100 or so you could buy a complete and properly running Onan, but as they say, "A bird in the hand...".
But, then again, this is from a guy who bought a cherry 120/240 BF for 50 bucks!
The Following User Says Thank You to lokay5 For This Post:
Old 06-30-2012, 05:11:22 PM
lol. I think i've pretty much have decided to stay away from it. I'm really looking for a 5.0-3c, but for some reason they are alot harder to find. I have seen them, but they're asking a arm and a leg for'em.
David
Old 06-30-2012, 11:46:35 PM
Billy J Shafer's Avatar
Pulling the battery off is not good and he is an idiot for doing so. I would stay away from it. Sounds like it has more problems than he is telling you about.
When I was a kid. People would pour lard into manual transmissions. Made them sound new for about a hundred miles.
Old 07-02-2012, 03:35:50 PM
Magnetite Magnetite is offline
His board is toast because he pulled off the battery. You'd want to replace it with relays anyway. It's not hard, but annoying to have to do. Definitely check for power. The other issues are minor. I own a 4.0CCK Spec R, and love it, but $200 is on the edge for me, and I'd be able to justify it as a spare parts machine for mine.
The Following User Says Thank You to Magnetite For This Post:
Old 07-02-2012, 06:41:48 PM
Default Re: Need opinion on Onan CCK spec R
Thanks for all the replies.
I think I made the right decision. Just too many things wrong with it.
David
The Following User Says Thank You to rcowboy For This Post:
Onan 7.5 DKD FJ Spec D Track29 Onan Generators 11 12-11-2011 04:12:27 PM
Onan 4. BGE spec E help please darrenholz Onan Generators 3 09-23-2011 09:11:09 PM
Need opinion on Onan 6.5NH-3CR/16004P Gen Set Mike Lucius Onan Generators 2 10-02-2010 08:14:51 PM
Onan 2.5 LK opinion bobbyz72 Onan Generators 6 09-06-2010 04:02:22 AM
Onan 15.0SC-CR/8388AB looking for opinion Max Thompson Onan Generators 7 12-10-2009 10:14:42 AM
