Monarch 30-20 and 30-18
this thread has 5 replies and has been viewed 2239 times
Old 09-22-2012, 11:44:01 AM
Joe P Joe P is offline
Default Monarch 30-20 and 30-18
A couple years ago I bought a 30-20 Monarch off of Stak and yesterday I had a chance to get the remains of a 30-18. My hope is to find a Beaver engine or a Lauson tractor thats in tuff shape to sacrifice for an engine. The biggest changes that I found so far between the two is 30-20 had a 7" frame, steering wheel and the gas tank mounted the long way and the 30-18 had a 5" frame, steering levers and cross mounted tank.
ID:	145475   Click image for larger version
The Following 12 Users Say Thank You to Joe P For This Post:
Old 09-22-2012, 05:31:23 PM
Brad Hauck Brad Hauck is offline
Default Re: Monarch 30-20 and 30-18
You could always use it to make a reproduction of the Rumely crawler Rumely definitely used a Monarch undercarriage on that prototype crawler.
Brad Hauck
Old 09-22-2012, 06:30:10 PM
Brad Hauck
I had that thought as well and that was my plan actualy till I got to see it and found the dive train complete. Also now that I know its different then the one I have I have more motivation to put it back the way it was. I got a couple leads on engines that I hope work out and maybe I can talk someone into casting a few pcs for me and it will be back to original.
The Following 2 Users Say Thank You to Joe P For This Post:
Old 09-25-2012, 08:08:06 PM
D'you know which Beaver/LeRoi you're looking for??
My old parts catalogs are all over the map on both Monarch and Lauson..
"C" 20-30---JB; 20-32 "C"--JC, JD (no yrs shown) (30 McCord)
"C" 24-29---JM (33 Perfect Circle)
"C" 20-30 1923-24---JB
"C" 20-30 1925-26 JC, JD (38 Victor)
"C" 20-32 1923-24---JA, JB
"C" 20-30 1925-26 JC, JMS (50 Fitzgld)
None I checked listed a 30-18.
Bvr/LeRoi JA/B/C and the JM are 4s; the JD and JMS are 6s.
The 30 McCord shows the JA and JB cast en bloc--one headgasket--and the JA, JB, JC, JD all cast in pairs--two head gaskets...it's no error as both gaskets are illus in both the McCord and the Vic.
The 38 Vic shows the JA/B/C/D all cast en bloc and the JB/C/D also cast in pairs (JA not in the 38 Vic)..
My Lauson listings aren't any better--Bvr/Lerois listed are JA,JA1,JAS and JS...JAS and JS are 6's per those catalogs.
Some of the confusion could be that a 4 and a 6 were offered for the same tractor models.
Thre were larger LeRoi RXs and RYs in the bigger Monarchs.
With sympathy, Bud
The Following User Says Thank You to Bud Tierney For This Post:
Old 09-25-2012, 09:17:30 PM
Bud the 30-18 in 1921 would have the 4.75" x 6" JB motor cast in pairs with open flywheel and my 30-20 has the JB with the solid block and open flywheel but I did some measuring and I cant see why the one pc block wont fit on the old style crankcase. Best I can tell is if you put the later block on the early crankcase you would only have a small gap in the middle of where it bolts down that wouldnt effect anything.
The Following 3 Users Say Thank You to Joe P For This Post:
Old 10-22-2012, 01:09:07 PM
Hootis Hootis is offline
What does the 30-20 need to be a runner next year?
Monarch Help oldironcollector Hit & Miss Gas Engine Discussion 4 11-06-2011 07:44:28 PM
Monarch 12 hp gen set Mark Mueller Vintage Diesel and Oil Stationary Engines 1 11-02-2009 03:20:45 AM
Monarch unrestored Edwin Hit & Miss Gas Engine Discussion 7 08-18-2008 08:30:50 AM
3HP Monarch Tom Winland Antique Engine Archives 0 09-29-2003 09:37:58 AM
7hp Monarch mike otis Antique Engine Archives 2 06-04-2001 07:30:18 PM
