Old Drill Press?
this thread has 7 replies and has been viewed 6809 times
Old 12-18-2012, 12:41:42 AM
Gary Dixon Gary Dixon is offline
Default Old Drill Press?
I found this old drill press today or I think it is a drill press, looks like it could be bolted to a wooden beam or wall, it all works, you can turn the wheel by hand or just to get the thing started, it is belt driven. The chuck is modern. I scraped the crud off of it and it says "Champion Blower and Forge Co., Lancaster Pa." on the back side it says "Warented" These is also a number 98 on a lever. Has anyone seen one of these?Click image for larger version
Name:	Drill Press 1.jpg
Name:	Drill Press 2.jpg
The Following 4 Users Say Thank You to Gary Dixon For This Post:
Old 12-18-2012, 08:08:52 AM
wagswitte wagswitte is offline
Default Re: Old Drill Press?
I have a couple of those out in the barn my dad used them once in awhile can't tell you much about it.
Old 12-18-2012, 11:24:58 AM
John Dunn John Dunn is offline
There would have been a shaft coming down from the mounting bracket with a work support table. The original chuck was just the 1/2" hole with set screw, the modern one will likely come out if you loosen screw. You sometimes see a few of the old drill bits with 1/2" shanks and a flat spot that were used with these.
Old 12-21-2012, 09:22:09 PM
PFT's Avatar
PFT PFT is offline
Commonly called a post drill, they were bolted to a post in the barn or shop almost every where. I knew a guy that had one bolted to a plank, it was his portable drillpress, just leaned it against the wall.
PT
Old 12-30-2012, 11:10:18 PM
GarysToys GarysToys is offline
The first interview I had when I was out of college, was for a engineering position at Champion Blower & Forge.
They were located on Harrisburg Pike in Lancaster, PA. and made a lot of the equipment we now collect.
Fortunately, I was also offered a job at DeWalt Saw in Lancaster for a few more $$'s.
The Champion factory closed and is now a row of resturants and small businesses.
DeWalt was purchase by Black & Decker which moved out a few years after the purchase.
Old 01-03-2013, 06:47:12 PM
Mike Grivna Mike Grivna is offline
We preserve / restore quite a few antique tools for our collection and sometimes for others if requested. These pictures are from a post drill we restored. It had minimal use but the paint was essentially gone. So glass bead and POR 15 paint. The mounting board is original with the stenciling intact. I also have several rare beam drills in excellent origional condition.
The Following User Says Thank You to Mike Grivna For This Post:
Old 01-03-2013, 09:18:43 PM
joelr4 joelr4 is offline
Here's an ad for this drill press:
Champion Blower & Forge Co. Drill Press
Also, here's the patent for your machine:
Patent #577,556
Joel
Old 01-07-2013, 11:23:30 PM
deadend deadend is offline
Check this out http://vintagemachinery.org/mfgindex/detail.aspx?id=165
Iding a drill press? 930dreamer Machine Shop and Tool Talk 1 08-21-2012 02:01:34 AM
Ashurst Press Drill Co. Fred Van Hook YouTube Old Iron Videos 0 07-08-2012 05:43:24 PM
My Drill Press ronny p 148 Small Air Cooled Gasoline Engines 7 01-08-2011 11:02:37 AM
Drill Press Chuck Repair old parts man Machine Shop and Tool Talk 6 03-25-2010 08:24:03 AM
How do you remove the chuck on a Nu-way drill press? Ben Clarke Machine Shop and Tool Talk 7 01-02-2010 10:53:39 AM
