BTU values of various fuels?
this thread has 2 replies and has been viewed 4257 times
Old 12-30-2013, 11:22:26 PM
Ken Karrow Ken Karrow is offline
Question BTU values of various fuels?
Can someone steer me to a web site or provide BTU contents of propane and hardwood pellets. I'm setting up and new shop and debating heating fuel. I have propane, will have to run line under ground to building, can buy pellets. Am also considering air conditioner with heat pump capabilities and propane or pellets as back up in real cold weather. Would like to have heater that uses outside air for combustion will sealed combustion, safer if one spills fuel. Am also considering propane heater near ceiling for the same reason. No longer in Colorado, have moved to west central Missouri. Thank you in advance. Ken
Old 12-31-2013, 12:32:32 AM
Ken Majeski's Avatar
Default Re: BTU values of various fuels?
Heres one I use http://nepacrossroads.com/fuel-compa...calculator.php
It's interactive you can type in different prices and efficiencies.
Ken Majeski, Ellsworth Wis.
The Following User Says Thank You to Ken Majeski For This Post:
Old 12-31-2013, 11:50:17 AM
DustyBar DustyBar is offline
The US Forest Service has one for various types of wood, moisture content and other fuels, http://hrt.msu.edu/Energy/Notebook/p...or_by_USDA.pdf. That document has a link to an Excel spreadsheet where you can plug in the values and compare costs for each fuel.
The Following User Says Thank You to DustyBar For This Post:
Fuels: white gas H Hennessy Hit & Miss Gas Engine Discussion 13 11-17-2009 10:15:33 PM
Different fuels redfish443 Hit & Miss Gas Engine Discussion 5 11-18-2008 08:39:20 AM
alternative fuels JBoogie Hit & Miss Gas Engine Discussion 15 08-26-2005 03:48:58 PM
Model Engine Fuels ?? Smoke Antique Engine Archives 13 05-07-2004 07:39:13 AM
Fuels--??? d.j.baisch Antique Engine Archives 10 11-26-2003 12:14:22 AM
