Power Products gas engine
this thread has 6 replies and has been viewed 2297 times
Old 01-24-2014, 07:22:31 PM
Peter Fisher Peter Fisher is offline
Default Power Products gas engine
I have Power Products, model 100, type 46, S/N 124945. I would like to know what year it was made and the HP. and any thing else about it. I would like to give a grand thanks to all that can help. Pete.
Old 01-24-2014, 07:29:46 PM
K-Tron K-Tron is offline
Default Re: Power Products gas engine
I have not heard of a model 100 before, are you sure it is not a model 1000? The model 1000 is a single cylinder engine with a 1.5" bore, 1.375" stroke, and is rated to produce 1hp @ 3800rpm. That particular model was built between 1952 and 1956
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 01-24-2014, 10:06:08 PM
Pete,
A Small Engines Service Manual, Second Edition published in 1955 that I have lists a Model 100 Power Products engine. It cross references to the model AH31-BO. That breaks down to a single cylinder engine with horizontal crankshaft with 3.1 cubic inches displacement. The B indicates a bronze connecting rod and O stands for open fan. Bore is 1 5/8" and stroke is 1 1/2"
I'm not aware of any serial number information showing date of manufacture and don't see any reference to horsepower in my manual. I'm guessing likely would be in the 1 to 2 HP range.
Bill
Old 01-25-2014, 07:57:49 AM
Hi Bill, what you stated about the engine, is what I have. On the bottom side of the crank case I found hand stamped numbers and I took that as being the S/N and that is just a guess on my part. Thanks, Pete.
---------- Post added at 07:57 AM ---------- Previous post was at 07:52 AM ----------
Hi K-Tron, your information helps. Thanks, Pete.
Old 01-25-2014, 11:40:56 AM
mschreiber mschreiber is offline
Another 1 for the trailer Pete? Looking forward to seeing it at sandwich!! Happy new year
Old 01-25-2014, 05:32:36 PM
Happy Hang Over,, OPPS,, I meant Happy New Year to you too. Pete.
Old 05-20-2015, 10:52:54 PM
Peter,
Just found the misplaced binder with my Power Products info that I've accumulated over the years while looking for a binder with info on a Craftsman riding mower. Anyway getting back to your original post, the Model 100 engine is rated at 1 HP @ 3200 RPM. At 3400 to 4000 RPM horsepower increases slightly to about 1.05 HP.
The information I have on the Model 100 is dated July 15, 1950.
Bill
The Following 2 Users Say Thank You to Bill Sherlock For This Post:
Power Products Engine Andrew Mackey Small Air Cooled Gasoline Engines 2 02-02-2011 10:27:04 AM
Power Products Engine C. Lambert Small Air Cooled Gasoline Engines 1 01-29-2011 07:59:29 PM
Power Products Engine C. Lambert Small Air Cooled Gasoline Engines 3 02-10-2010 07:01:12 PM
Got a Power Products engine Can someone age for me? Dennis Wyatt Small Air Cooled Gasoline Engines 1 12-18-2008 01:06:59 AM
Power Products Engine Charlie Allen Antique Engine Archives 0 09-05-2002 11:34:37 PM
