Stover 1/4 hp hit miss engine
this thread has 22 replies and has been viewed 2726 times
Old 01-26-2016, 03:47:16 PM
David Schmidt David Schmidt is offline
Default Stover 1/4 hp hit miss engine
I have a Stover 1/4 hp hit miss engine tag states: 1/4 hp, 350rpm.
serial #0003. It has 8" flywheels . Anyone know anything about this
Engine?
Old 01-26-2016, 03:49:58 PM
Doug Kimball's Avatar
Default Re: Stover 1/4 hp hit miss engine
David,
Can you post a photo? Sounds very unusual!
In Kennebunk, Maine;
Doug Kimball
The Following User Says Thank You to Doug Kimball For This Post:
Old 01-26-2016, 04:11:45 PM
I will post photo soon. This sure looks like a production engine not a home workshop
model.
David
Old 01-26-2016, 04:57:11 PM
OTTO-Sawyer's Avatar
Gotta be a model, but I can't wait to see some pictures of it.
Oh, and Welcome Aboard the Stak.
Old 01-26-2016, 05:46:52 PM
Walt Potoniec Walt Potoniec is offline
sounds like a stover duro pump engine.
The Following User Says Thank You to Walt Potoniec For This Post:
Old 01-29-2016, 05:13:42 PM
didn't think about that one.....
Still hoping to see some pictures of it.
Old 01-29-2016, 06:02:48 PM
Bob Krummel Bob Krummel is offline
A Stover Duro has flywheels a little more than 10"...... at least that's what I came up with in the dark, without my glasses, buried under some stuff, and with a mini tape measure.
The Following User Says Thank You to Bob Krummel For This Post:
Old 01-31-2016, 01:50:17 PM
Photo Re: Stover 1/4 hp hit miss engine
Stover 1/4 hit miss engine photos
ID:	245182   Click image for larger version
ID:	245183   Click image for larger version
The Following 6 Users Say Thank You to David Schmidt For This Post:
Old 01-31-2016, 02:18:20 PM
David,
It appears that your engine was machined from a model casting kit. I'm not sure who sold these kits or if they are still available. You may try the Scale Model Engine forum for a better answer.
Doug Kimball
Old 01-31-2016, 03:14:35 PM
Thanks Doug
Dave
Old 01-31-2016, 03:26:11 PM
Gil Garceau Gil Garceau is offline
Hi David, I can be corrected if someone knows different but I don't see much that looks like a castings kit there. I think it may be nearly all home shop built except the crank and connecting rod may have come from a Briggs and Stratton mower engine or similar. Looks like a fun to run little hit and miss engine.
Gil
My youtube channel: http://www.youtube.com/user/reddrryder/videos
The Following User Says Thank You to Gil Garceau For This Post:
Old 01-31-2016, 05:32:43 PM
Tim Christoff Tim Christoff is offline
I agree with Gil, most of it is home made.
Tim.
The Following User Says Thank You to Tim Christoff For This Post:
Old 01-31-2016, 07:30:58 PM
Whoever built it, there should be at least 2 more of them out there with this one being number 0003.
That serial number was the main reason I figured it was a model by the original description.
That and the 1/4hp and 8" flywheels.... but mainly the #0003
Nice looking little engine whoever built it.
Old 01-31-2016, 07:48:39 PM
Thanks everyone for your info.
This little engine will be fun to run.
Dave
Old 02-11-2016, 09:01:01 AM
I remember, years ago at Cabin Fever, a guy had a real nice running 1/5 scale Stover model "U", hopper cooled. He was going to offer a limited run of finished models after getting all the bugs worked out. For some reason they were never made .
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
The Following 2 Users Say Thank You to Paul Spence For This Post:
Old 02-11-2016, 11:24:12 AM
Jamesk815 Jamesk815 is offline
David
Does it look like this?
If so that makes 4 that I know of the I have one , the Bishop guy's in Indiana have one , and Mr. Davis in California has the other. All I can find out about them is, that a man in Florida is supposed to have made 10. They are mostly made out of bar stock, and the guy did a great job of building them .Mine runs well. They are quite heavy. The mag actually trips on mine, but is none functional. All of them are set up like mine, and I see yours is built a bit different,
so maybe not the same guy. There are no Briggs parts in mine . I did a post in the model forum on mine a couple years ago, so you can look it up if interested.
Hope this helps .
ID:	246126   Click image for larger version
The Following 3 Users Say Thank You to Jamesk815 For This Post:
Old 02-11-2016, 05:40:59 PM
Sprintcars11 Sprintcars11 is offline
Can we see a video of this running?
The Following User Says Thank You to Sprintcars11 For This Post:
Old 02-11-2016, 05:49:01 PM
Smile Re: Stover 1/4 hp hit miss engine
David
After studying yours, I don't think they were made by the same guy. your gov. is on the flywheel mine is on the block also different carb than mine. I don't have a video of mine running sorry.
The Following User Says Thank You to Jamesk815 For This Post:
Old 02-11-2016, 06:35:57 PM
Amax Amax is offline
From the material and etching of the brass plaque to the type of hardware (bolts and screws) to the 'modern' connecting rod and piston, it does not look too old. Maybe 1980s?
The Following User Says Thank You to Amax For This Post:
Old 02-18-2016, 12:07:15 PM
It is not quite ready to run. Needs ignition system I am new at this . It has a buzz coil.
and points no wiring though. Anyone with any luck with the electronic Hall type sensor
units? Our should we stick with the point ignition?
Dave
Stover Model KA Hit Miss Gas Engine Question bt2461 Hit & Miss Gas Engine Discussion 3 05-04-2014 10:23:11 AM
stover 2 1/2 hp hit+miss lotsasteam Hit & Miss Gas Engine Discussion 3 01-08-2013 11:24:26 AM
Stover V Hit and Miss Engine George Taylor Hit & Miss Gas Engine Discussion 9 05-05-2012 11:45:00 AM
Need help with Stover Rex hit miss engine Jacob WI Hit & Miss Gas Engine Discussion 20 09-04-2009 08:42:11 AM
1929 Antique Farm Sprayer with Stover Hit Miss Engine Mel1 Hit & Miss Gas Engine Discussion 7 11-27-2005 10:59:44 PM
