Wind power generator?
this thread has 3 replies and has been viewed 1570 times
Old 09-10-2016, 11:57:31 PM
Default Wind power generator?
I was working on an electric wheel chair and in the manual it talked about regenerative braking. So I was wondering if wheel chair motors would work in a wind generator? There was two electric motors and 2 12 volt batteries on the wheel chair. I have no real info on the motors, but seems like they would be 24 volt motors. Any thought out there about this?
Richard W.
Old 09-11-2016, 12:38:17 AM
Default Re: Wind power generator?
A question of start up speed. You have to run a higher voltage into a battery than rated battery voltage before it will begin to charge. On cars etc. that is usually set between 13.5-14.3 volts. Call it 13 volts minimum.
Drive motor using a variable speed drill and read output volts from motor with a meter. Measure RPM. That is the minimum RPM the wind must drive motor.
Doc
Old 09-11-2016, 05:06:16 AM
Yes it is possible with permanent magnet generators, if you want more info and an unbiased opinion, send me a pm. It takes a little bit of explaining............
Old 09-11-2016, 05:14:03 AM
Elden DuRand's Avatar
Permanent magnet motors (not brushless) make decent generators. The only real drawback is that voltage regulation is more complicated and requires more powerful components.
With a wound field motor, output voltage is regulated by varying the relatively small current in the field winding. On the other hand, the output of a permanent magnet generator has to be regulated.
On the permanent magnet motors I've used as generators, the RPM is about the same as or slightly higher than the RPM it runs as a motor.
The most unusual motor I've used as a generator is the motor from a direct drive (gearless) washing machine. Here's the deal on that one.
http://www.eldensengines.com/Washing...20Project.html
Have fun!
[SIGPIC][/SIGPIC]
Take care - Elden
Finally, solar and wind power are not intermittent! len k Solar and Wind Power for Home, Farm & Industry 28 02-23-2016 01:17:33 AM
Onan Genset and wind power system conceptual mronkar Onan Generators 5 07-18-2013 12:02:22 AM
Solar and Wind Power keyturbocars Solar and Wind Power for Home, Farm & Industry 2 11-25-2012 02:29:42 AM
Wind Power Unit Ihorse Solar and Wind Power for Home, Farm & Industry 1 12-12-2005 11:08:35 AM
Wind Power Gen. Andrew Generators & Electric Motors General Discussion 2 03-31-2004 12:48:42 AM
