Generators, Large Loads and Off Grid Living
this thread has 21 replies and has been viewed 2489 times
Old 04-10-2018, 11:31:16 AM
csareb csareb is offline
Default Re: Generators, Large Loads and Off Grid Living
All right. Thank you.
Old 05-31-2019, 05:14:28 PM
dkamp dkamp is offline
eMail NOT Working
Default
Wow you spend a lot money on fuel? I been off grid for 17 years and never used that much fuel in a month. Use oil heating for hot water and heat. half a gallon per hour.
Currently upgrading to a new 7kw Kubota electricity for the cabin and hot water heating for the shop . . ah I guess 3.5 kw of solar and 18kw of battery bank helps
I have 6 months of winter here as well.
go get an oil fired hot water tank or boiler . or best build your own wood fired with and add on oil burner on the side .
Onan Generators for large 5th wheel RocklandValley Onan Generators 31 02-17-2016 09:35:46 PM
Kholer 3.5 cm 21I'm living off grid and I need help diagnosing chip23 Kohler Generators 3 07-18-2015 09:11:58 PM
Wisconsins and Lincoln, loads of engines, welders and generators Thiel Generators & Electric Motors General Discussion 7 11-21-2012 07:33:23 PM
Running a large DC motor from two generators? jlrsp3 Generators & Electric Motors General Discussion 19 06-28-2010 08:41:24 AM
Manuals for large Onan generators? Jeffw5555 Onan Generators 6 01-16-2006 03:03:33 PM
