Power Products AH47 Questions
this thread has 14 replies and has been viewed 903 times
Old 12-03-2018, 12:34:06 PM
Mike Stroz Mike Stroz is offline
Default Power Products AH47 Questions
Just ordered one of these little engines off ebay for a good price to put into a mini bike project I'm working on, but I have a few questions. I've found very little info on these things on google. First, what size output shaft does it have? I'd assume 5/8" but not sure. Second, I'm planning on using modern synthetic oil in it, should I use the same ratio (16:1 I think) as stock? Or should I stick with straight SAE 30 oil like I use in my Maytags? Third, Does anyone have a muffler/ exhaust for one of these? Mine has a chainsaw type exhaust coming straight out the side which will be right into my ankle when it's on the mini bike. I'd like to get an exhaust that exits forwards toward the spark plug, rearwards toward the carb or down to the ground. Lastly, what kind of horsepower does this make? I've seen people say anywhere from 1.5 to 5 hp, nothing definite. I'll post some pictures when it arrives, I'm pretty excited to put it on something
Old 12-03-2018, 01:11:12 PM
Default Re: Power Products AH47 Questions
According to information I have the AH-47 engine is rated at 2 HP. They were built from 1948 to 1955.
Bill
Old 12-03-2018, 01:46:28 PM
Ok thanks. That's a little smaller than I hoped but it should be fine for such a small mini bike frame. I guess I'll keep my eye open for something larger though. I still want to find a Clinton Panther but I can't seem to find any for a decent price
Old 12-03-2018, 02:21:54 PM
Ken Karrow Ken Karrow is offline
If it were mine, I would not use synthetic, 30 wt non detergent would be my choice.
Old 12-03-2018, 02:38:06 PM
Ok, I'll use that then. I've got a bunch of old cans of 30w oil from the 40's and 50's I've been using for my Maytags
Old 12-03-2018, 03:45:00 PM
K-Tron K-Tron is online now
AH-47 is 2hp. They were used in thousands of different chainsaws. 5/8" shaft is likely what it has if it came out of a saw. Beware of which way the engine turns for your project. 16:1 is what I use in my power products engines. Depending on the spec number it will either have needle bearings or a brass connecting rod riding on a steel crankpin. The more oil the better. I run Valvoline TCW-3 mixed with all of my two stroke engines.
Chris
Old 12-03-2018, 05:37:01 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
I have a couple of different exhaust fittings for these engines. Don't know their origin or remember where I got them, but pictures will show what they are.
One looks like it would accept tubing for a muffler / expansion chamber or just a straight pipe. The other is a shorty, possibly from a chain saw. No baffles or other sound attenuating features, just a cast aluminum deflector of sorts.
Name:	PP Exhaust 01.jpg
ID:	323910   Click image for larger version
Name:	PP Exhaust 02.jpg
ID:	323911   Click image for larger version
Name:	PP Exhaust 04.jpg
ID:	323912   Click image for larger version
Name:	PP Exhaust 05.jpg
ID:	323913   Click image for larger version
Name:	PP Exhaust 06.jpg
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 12-03-2018, 06:55:06 PM
Wow, those are some really cool pieces. I like the larger white one a lot! I don't think the original exhaust had much in the way of baffles, mine has a regular chainsaw muffler that's pretty much straight through. If you'd be willing to let one or both of them go I'm definitely interested.
Old 12-03-2018, 09:09:09 PM
Originally Posted by Mike Stroz View Post
Just ordered one of these little engines off ebay for a good price to put into a mini bike project I'm working on...
Hmm, good idea. I have been trying to figure out what to do with this apparently rare Clinton. Maybe I'll make a somewhat more powerful mini bike.
Old 12-04-2018, 12:01:55 PM
That would probably be really good in a go kart, might be too wide for a mini bike. But I would be hesitant using that for anything too strenuous. Those 2 cylinders are super rare. Only made for that specific generator for the military as far as I know
Old 12-04-2018, 06:56:33 PM
I probably won't do anything with it right away, I got it mostly to save it from the scrap yard. But the thought of a 2 cylinder, 2 stroke mini bike was a neat mental picture anyway.
Old 12-04-2018, 07:55:19 PM
Maybe you could put it in a fairly long mini bike longitundinally with a 90 degree gearbox behind it. Might look good with the bike painted up in olive drab to match the engine
Old 12-04-2018, 09:48:15 PM
gdstew gdstew is offline
I have a dozen Tecumseh 2-cycle engines from snowblowers, thought about maybe 6 of them in a long mini bike! Too many other projects first.
Old 12-05-2018, 10:04:33 AM
I've got one of those too I wanted to put in this bike but the 1" output shaft is a pain to find a clutch for
Old 12-14-2018, 10:38:57 PM
Just got my new AH47 in the mail today. Unfortunately the gas filler got a big dent in transit so there's no way it's going to have a good seal, and the other problem is a bad rod knock. I went as far as taking the carb and reed valves off and the crank looks good from what I can see. Is there any good parts source for these engines? I really want to get it going again amd it looks like I only need a new rod and some gaskets. *knock on wood*
Power Products AH47 decals desotonut1953 Small Air Cooled Gasoline Engines 3 11-21-2018 09:21:31 AM
Power Products AH47 help thambach Small Air Cooled Gasoline Engines 22 12-29-2013 08:42:00 PM
Clinton D55 & Power Products AH47 saws Nevr-Enuf-Stuf Chain Saw Collectors 4 08-10-2011 05:20:40 PM
Power Products AH47 info needed pioneer fan Chain Saw Collectors 4 08-07-2009 11:53:19 PM
Power Products AH47 - How to time it?? Kammer0072000 Small Air Cooled Gasoline Engines 4 03-27-2009 10:25:51 PM
