Paint Shop
Can I brush paint Centauri (acryl. enamel)?
this thread has 3 replies and has been viewed 7370 times
Old 12-10-2005, 06:19:35 PM
Brent Rowell Brent Rowell is offline
Default Can I brush paint Centauri (acryl. enamel)?
Does anyone know if I can brush paint DuPont Centauri acrylic enamel with any success? If so, what sort of thinner/reducer or whatever should be added? Thanks.
Old 12-11-2005, 11:58:20 AM
Exclamation Re: Can I brush paint Centauri (acryl. enamel)?
It is difficult, but can be done, you have to work fast, neat, and cannot go over freshly painted areas until dry. Also, and most important - YOU MUST wear protective breathing equipment - mask - as the fumes cause brain damage if inhailed for extensive periods. I would not advise painting inside the home or closed garage! Outside - open air exposures only! Also, there are temperature - humidity considerations as well.
Old 02-20-2011, 11:14:20 PM
IronworkerFXR IronworkerFXR is offline
Default Re: Can I brush paint Centauri (acryl. enamel)?
I agree !!, also use less reducer and a better brush, not the cheap $1.00 chip brushes , get a good oil paint brush
Old 02-20-2011, 11:22:25 PM
Jeff Miley Jeff Miley is offline
I have brushed on Centauri and also Ful-thane which is another DuPont paint sold under the company name Nason. If you blast the old iron clean much is pitted and porous. It is hard to get the amount of paint on necessary to fill the voids without using filler of some type. With a brush you can get decent results. Another thing you cando if after all parts are assembled you can spray a coat over the brushed on to get a better finish. Like other have said, be careful of the fumes and watch overspray on everything else in the shop.
Enamel Engine Signs Jeff in PA Hit & Miss Gas Engine Discussion 2 07-22-2018 10:49:41 AM
Dupont Dulux Enamel Dusty Hit & Miss Gas Engine Discussion 7 07-29-2017 10:53:00 PM
Thinning Enamel Paint Jim M. Paint Shop 9 02-20-2011 11:39:26 PM
Clear enamel spray paint David Babcock Hit & Miss Gas Engine Discussion 15 08-11-2009 07:55:30 AM
When Will We Not Be Able to Purchase Lacquer and Enamel Paint? DougM Paint Shop 15 01-22-2009 11:07:34 PM
