Oil Field Engines
Half breed, how it works?
this thread has 5 replies and has been viewed 3001 times
Old 08-06-2008, 03:47:20 PM
irvon irvon is offline
Default Half breed, how it works?
hi ,new at this, is there an anamation on the half breed, does the piston have a valve, this engine looks like a fun one to model, are the plans
thank you.
Old 08-06-2008, 05:03:05 PM
Elden DuRand's Avatar
Default Re: half breed, how it works ?
Irvon:
"Half Breed" engines are steam engines that have been converted to internal combustion engines. This is usually done by scrapping the cylinder and valve chest and substituting a cylinder with valves and hot tube or spark plug.
In other words, most of the engine is re-used when it is converted.
Take care - Elden
http://www.oldengine.org/members/durand/
Old 08-11-2008, 08:53:29 AM
Default Re: Half breed, how it works?
thank you. the one i saw running had a stuffing box on the piston rod , same as double acting steam.the intake air seamed to enter at the rod end of the cyl ,on the compresion stroke,how dose the air get to the head end? some air must enter at the head to pull in the gas charge. this engine looks so simple but has me baffled thank you for your help.
Old 08-11-2008, 09:18:16 AM
Irvon:
The half-breeds with a stuffing box for the bottom of the piston are 2-cycle. The space below the piston is used to draw in the fuel/air charge and force it into the area above the piston. There's a transfer port between the bottom and top half and usually a check valve.
Otherwise, they operate just like a 2-stroke chain saw, etc.
Take care - Elden
Old 08-11-2008, 03:37:35 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Go to Google patents and enter 626155. This is the original Fithian patent on a conversion cylinder to make a gas engine from a steam frame.
http://www.google.com/patents?id=2X5..._pages&cad=0_1
The Following 2 Users Say Thank You to PaulGray For This Post:
Old 08-13-2008, 08:31:14 AM
thank you the patent is a good resource big help!
Oil City Half Breed Engine john_deere Oil Field Engines & Related Equipment 6 07-21-2008 01:55:23 PM
Half breed engine Andrew Mackey Oil Field Engines & Related Equipment 3 07-28-2006 10:14:44 AM
Half-Breed Ball Steve NW Ohio Oil Field Engines & Related Equipment 1 10-26-2005 02:15:52 PM
Coolspring Half-Breed pics. tremel Antique Engine Archives 30 06-26-2004 08:57:07 AM
valve body half breed Lyle Fall Antique Engine Archives 1 02-12-2003 09:40:03 PM
