Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Replacement Spark Plug for Maytag Uprights?? Modern Plug?
this thread has 3 replies and has been viewed 4241 times
Old 08-30-2008, 12:09:18 AM
enginesilo's Avatar
enginesilo enginesilo is offline
Question Replacement Spark Plug for Maytag Uprights?? Modern Plug?
What is a good replacement spark plug for the Upright engine's? Is there a newly manufactured plug like an Autolite or Champion that will do the trick?
I've seen newly manufactured Champion X's that are the old school 2 piece type. Is that a good plug? Is there anything else that is a common modern cheaper plug to run on?
What brand and model are best?
Old 08-30-2008, 05:03:47 PM
enginesilo's Avatar
Default Re: Replacement Spark Plug for Maytag Uprights?? Modern Plug?
I was told the Autolite 3095 is a good plug for both the Maytag 92's and the Uprights. Anyone disagree or is that a good replacement for the uprights?
Old 08-30-2008, 08:25:13 PM
bstrucker's Avatar
bstrucker bstrucker is offline
I've used the 3095s in 92 engines and they work fine.
Old 08-31-2008, 01:21:57 AM
Exclamation Re: Replacement Spark Plug for Maytag Uprights?? Modern Plug?
Original champion 34, or the Gas Engine special, find here on sponsor pages or evil bay. Maytag also had champion make dedicated plugs for their engines - they had the word Maytag fired into the insulater. They come in 14mm (for the twins, and 1/2" pipe base - for all the other engines, both uprights (all 3), the 82 and 92 engines, and all others. these are all long reach plugs, to get the spark deep into the combustion chamber. the Champion A-25, and the Autolite 3095 will work too, but I like the older plugs better.
Spark Plug to use in a Maytag 92? enginesilo Maytag Engines and Collectibles 11 05-27-2008 11:01:46 AM
Replacement spark plug for 1924 M Donald A Smith Hit & Miss Gas Engine Discussion 2 01-16-2008 05:25:39 PM
Maytag 72 spark plug The one banger boy Hit & Miss Gas Engine Discussion 15 09-03-2007 09:10:44 PM
Spark Plug Cross/Replacement WilliamD Small Air Cooled Gasoline Engines 7 11-20-2005 08:49:19 PM
Spark Plug ? Bill Schmidt Onan Generators 1 12-19-2004 12:02:15 PM
