Go Back   SmokStak > SmokStak® Antique Engine Community > Vintage Diesel and Oil Stationary Engines
Vintage Diesel and Oil Stationary Engines Fairbanks Morse, Lister, Petter, Witte and other pump injected Diesel oil engines.
Monarch 12 hp gen set
this thread has 1 replies and has been viewed 2070 times
Old 11-01-2009, 05:10:49 PM
Mark Mueller Mark Mueller is offline
Default Monarch 12 hp gen set
Can anyone tell me how to get the injector pumps pumping?
Old 11-02-2009, 03:20:45 AM
ListerDiesel's Avatar
Default Re: Monarch 12 hp gen set
You'll need to bleed the air out if they have run dry, and if they have seized up, then you'll need to strip them down and get them cleaned up.
Bleed nipples are on each pump, open and hand pump the fuel up until air bubble stop then close the bleed nipple while fuel is still coming out.
Monarch used a basic Lister diesel twin that they added their own parts to for the generator.
Peter
Help Please - Monarch (Nelson) 1 3/4 hp peterR Hit & Miss Gas Engine Discussion 4 08-02-2008 07:29:17 PM
different carb. set up on monarch BDMelon Hit & Miss Gas Engine Discussion 0 10-02-2005 07:14:44 PM
Monarch Engine 1 1/2 HP Ken Adamson Hit & Miss Gas Engine Discussion 2 01-12-2005 06:17:58 PM
3HP Monarch Tom Winland Antique Engine Archives 0 09-29-2003 09:37:58 AM
7hp Monarch mike otis Antique Engine Archives 2 06-04-2001 07:30:18 PM
