Onan 15.0SC-CR/8388AB looking for opinion
this thread has 7 replies and has been viewed 1216 times
Old 12-08-2009, 05:25:41 PM
Default Onan 15.0SC-CR/8388AB looking for opinion
ONAN 15.0SC-3CR/8388AB SER.# I870928065
I am thinking of adding this generator to my collection. Currently have a 30.0 SK, 15.0 JC, 4.0 MCC, 3.0 AJ, & a 1973 2.5 LK. Someday I will get pictures of them all & post. I am sure this Web Site should come with a “Warning Label”, it is like giving a alcoholic a drink.
Is the 15.0SC similar to the JC series of the same size. I am not familer with the SC model, (not that I know much about any of them, but love to tinker & listen to them run). Seems the JC series has a great track record, is the SC series in the same class ?
If Jim Davis is reading, can you tell me from the numbers if this generator was built with a dual fuel carburetor? I have not seen the generator yet, it is about 200 miles away but may take a trip in the near future depending on what the “smart guys” have to say.
Thanks to all who make this site what it is. It is comforting to know I am not the only Onan junkie in the world.
Old 12-08-2009, 05:56:54 PM
JCarroll JCarroll is offline
Default Re: 15.0sc-cr/8388ab looking for opinion
Max, have them confirm the model number - I think you will find it is a JC.
15 KW - 120/240 1ph - YD end - built in Sept. 1987.
A picture is worth 1000 words.
Old 12-08-2009, 09:02:26 PM
It does look like a JC in the picture I got. Maybe this is why I have not read anything on a SC.
Old 12-09-2009, 06:10:39 PM
"I am sure this Web Site should come with a “Warning Label”, it is like giving a alcoholic a drink."
That is an understatement - I'll have a double....
Old 12-09-2009, 07:04:29 PM
Isaac-1 Isaac-1 is offline
Its not that bad, I only have 8 Onan generators on my current GL auction watchlist, and 5 of those are less than 10 miles away. Of course the 3 I would be most likely to bid on are all in the 400 mile away range. 2 of the 5 nearby units are a little larger than I could justify needing (well a little larger than I can justify as a backup for work in place of our 125.0DYD they are in the 150-230 KW range), the other 3 are 345KW, which is A LOT more than I can justify.
Ike
p.s. there is also that other bit about my wife thinking remodeling the kitchen and the living room is more important than another generator (of course she feels the same way about air compressors, boats, and all sorts of other things)
Old 12-09-2009, 08:42:25 PM
Dave Edmonds's Avatar
Dave Edmonds Dave Edmonds is offline
Default Re: Onan 15.0SC-CR/8388AB looking for opinion
Women gripe about generators and the time/money spent UNTIL the power goes off! When (in my case) you walk outside, hit the start switch, pull the handle on the transfer switch, and walk back inside to a functioning house, they suddenly understand what the thing is for.
Dave Edmonds
Old 12-10-2009, 07:51:44 AM
I DO NOT have a problem (unless I can't fix this RDJF ).
Old 12-10-2009, 10:14:42 AM
K D Redd K D Redd is offline
I did not have ONE complaint from the better half when I bought my $100
4CCK. She still remembers the 6 day power outage we had caused by an ice storm about 3 years ago. I had 2 generators that keep my wife and I and her father in our homes during this time. I now have three more generators than I had then. None of very high capacity but I found that ANYTHING that could generate 60 HZ AC was worth having around. I have a little 300 watt unit that was enough power for a couple to run their pellet wood stove and a light or two. This keep them in their home and keep their pipes from freezing.
Kent
I would like your opinion. Attakapas24 Generac Generators (SEARS, etc.) 6 05-17-2009 02:53:22 PM
In your opinion Benny Mckheean Hit & Miss Gas Engine Discussion 17 11-02-2005 03:03:26 AM
Opinion on 0-W40 oil in my DJC J. McNugget Onan Generators 5 10-31-2005 10:46:45 PM
Your opinion please. Frank Y Antique Engine Archives 10 07-07-2003 08:23:33 PM
Your opinion of the best? Bill Blackburn Antique Engine Archives 12 11-06-2002 11:20:18 AM
