Paint Shop
Primer to Paint
this thread has 4 replies and has been viewed 2314 times
Old 07-27-2010, 09:24:38 PM
bfmco7 bfmco7 is offline
Default Primer to Paint
How long should I wait between primer and the first coat of paint?
Old 07-27-2010, 09:51:11 PM
Rod Fielder Rod Fielder is offline
Default Re: Primer to Paint
What kind of primer and what kind of paint
Old 07-28-2010, 11:36:32 AM
Exclamation Re: Primer to Paint
READ primer directions! Also, prime a hidden area or waste paper, and test for compatability between primer and paint. While painting parts for a fire truck, we found that the paint crazed the primer, ruining the painted surface. It had to be stripped down to metal and be redone in compatable materials. Most primers need 24 hours, in an area with less than 30% humidity. If the area is humid, rust may occur under the paint layer.
Primer is just that - a surface that is condusive to paint adhesion. It makes for a better surface for paint to stick to, than bare metal or whatever undersurface you have. It does NOT seal the surface, or protect it in any way. If the surface that is primed gets wet, it must be sanded back to bare metal, or rust will occur. Only paint will seal the surface from moisture.
Old 07-28-2010, 01:21:05 PM
Well.. that surely narrows It down for me.. Im using john deere paint so I may as well use john deere primer.
Old 07-28-2010, 02:55:22 PM
any primer and paint without a catalyst is truely a waste of time and money, period............
Paint and Primer Dan Dyman Steam Stationary Engines, Traction Engines 9 04-17-2008 04:24:42 PM
To Primer or Not ??? dusty Paint Shop 2 10-17-2003 06:02:18 PM
What primer & paint for a pump? David Swa nson Antique Engine Archives 0 06-10-2003 09:22:45 PM
primer and paint roy bartlett Paint Shop 12 02-06-2003 11:58:23 PM
paint and primer Eric M Antique Engine Archives 6 07-03-2001 08:01:44 PM
