Paint Shop
Mixing Dark Cherry Red Paint
this thread has 5 replies and has been viewed 13840 times
Old 07-28-2010, 05:18:09 PM
ALora ALora is offline
Default Mixing Dark Cherry Red Paint
I am having trouble getting a dark cherry red paint using basic oil base enamel. Paint store simply mixes black into red base but I get rust color then if more black is added sort of brown purple. I want to match the red on an old engine which still has most of the original paint. Where the old paint is not damaged by dirt and chips it appears beautiful. I have made some replacement parts, so I want to retain original paint if possible. I can mix the paint dark enough but not dark and red enough.
Old 07-28-2010, 06:28:30 PM
Rod Fielder Rod Fielder is offline
Default Re: Mixing Dark Cherry Red Paint
go to auto paint supplier and look at the color chip books. they can mix it while you wait.
Old 07-28-2010, 07:53:47 PM
SteveK SteveK is offline
I have had good luck as Rod said at an auto paint supplier.
I have great luck with acrylic enamel, its old fashioned but spays on easy, shines and tolerates gas and oil.
My local paint supplier can also mix a custom color and put it in an aerosol can somehow,which is handy.
On the level
Old 07-28-2010, 11:39:29 PM
Exclamation Re: Mixing Dark Cherry Red Paint
Find a Sherwin-Williams acryllic paint dealer. They can computer match a paint chip and mix the paint you need.
To darken red, you actually have to add blue to it. Black really won't work. As Steven K noted, it can be put in rattle cans, or be sold by the quart. In my experiance, rattle can shelf life is about 6 months.
Old 01-18-2011, 09:29:17 AM
Dave Thompson Dave Thompson is offline
Thought i would try mixing a little blue in my bright red paint and it worked great to darken the red ,thanks Andrew ,these posts are the best Thanks Harry!
Old 01-19-2011, 02:36:22 AM
John Hanson John Hanson is offline
Yep, BLUE is used to darken reds..... I used to love mixing the colors when I was part owner in the paint mfg business!
JH
The cherry on top... jht1057 Scale Model Engineering 1 11-11-2009 11:45:05 AM
Onan paint mixing and matching J. McNugget Onan Generators 3 08-24-2006 07:02:34 PM
A shot in the dark Brian Lynch Antique Engine Archives 6 01-20-2003 12:02:11 AM
Lifting with Cherry picker Tom Winland Antique Engine Archives 11 09-23-2002 11:03:18 AM
hot tube-cherry red? walter Antique Engine Archives 7 01-27-2001 10:23:02 PM
