Onan 2.5 LK opinion
this thread has 6 replies and has been viewed 1732 times
Old 08-31-2010, 09:24:28 PM
bobbyz72 bobbyz72 is offline
Default Onan 2.5 LK opinion
Ok, i got a trifuel, 2.5lk a couple weeks ago, it was half buried under ground sitting next to an old dodge RV. Long story short, i pulled it out of the ground with my truck. Brought it home, took it appart, piston had ant nest on top of it, and was packed full of dirt, so you can imagine what it looked like. I got everything sandblasted, painted, and had a +.020 piston installed, and head very slightly machined down to increase compression for natural gas use. Question is, how should i set my timing for max power/efficiancy. Im going to do electronic ignition. The timing is supposed to be set at 19 btc, sould i retard or advance? Id like to set at 21btc, what do you guys thing. I can change it to anything, just that 21btc would be the easyest.
Old 09-01-2010, 10:21:52 AM
Billy J Shafer's Avatar
Default Re: 2.5 LK oppion
I would say on this. Just try and see what works the best. The LK was a very good unit.
Old 09-01-2010, 09:23:53 PM
David C David C is offline
I believe the N/G fueled 5.0CCK's call for 21 degrees BTC. Since the 2.5LK is half of a 5.0CCK, it should be fine. There was a 2.5LK around Bastrop for $50.00 that did not look too bad on Craigslist. It did not stay on Craigslist too long though.
David C.
The Following User Says Thank You to David C For This Post:
Old 09-02-2010, 08:45:47 AM
Esteban32696 Esteban32696 is offline
I have a 1968 2.5 LK-1R that I use for back up. I run regular gas & it comes in handy when I lose power.
Old 09-05-2010, 09:07:38 PM
Default Re: Onan 2.5 LK opinion
workin progress
ID:	86631   Click image for larger version
Old 09-05-2010, 09:24:03 PM
Gunny Gunny is offline
Adjust the timing to get the highest intake manifold vacuum.
Old 09-06-2010, 04:02:22 AM
DaGr51 DaGr51 is offline
Looks good, Bobby!
The Following User Says Thank You to DaGr51 For This Post:
Onan 15.0SC-CR/8388AB looking for opinion Max Thompson Onan Generators 7 12-10-2009 10:14:42 AM
I would like your opinion. Attakapas24 Generac Generators (SEARS, etc.) 6 05-17-2009 02:53:22 PM
In your opinion Benny Mckheean Hit & Miss Gas Engine Discussion 17 11-02-2005 03:03:26 AM
Your opinion please. Frank Y Antique Engine Archives 10 07-07-2003 08:23:33 PM
Your opinion of the best? Bill Blackburn Antique Engine Archives 12 11-06-2002 11:20:18 AM
