HELP! WWII vintage lathe
this thread has 6 replies and has been viewed 2936 times
Old 09-22-2010, 05:30:45 PM
halh123 halh123 is offline
Default HELP! WWII vintage lathe
I have an offer to acquire an antique WWII gear head lathe that was originally owned by the military. It was made by Reed-Prentice Corp. is 16 inch and looks to be in fairly good shape.
Has anyone had any experience with this model lathe? I would like an opinion as to whether it would be worth the cost of having it moved to my home shop. I have 230 volt 3 phase power available. Would also like to get an operating manual. I'll need help in determining the function/purpose for all the knobs and levers. Any help will be great fully appreciated.
Old 09-22-2010, 08:09:28 PM
OTTO-Sawyer's Avatar
Default Re: HELP! WWII vintage lathe
Should be a good heavy duty lathe.
Our club in Freeport IL has one of those that's drying out from the July flood we suffered from.
As for all of the knobs & levers, they should all be marked with big brass tags showing the RPM ranges and quick change feed gear selections. If your tags are missing, I can post pics from ours, but as I am running out of space to post more pictures, I'm holding off on posting any of those until I know if you need them or not.
Gear drive lathes in general are more heavy duty than belt drive ones, and I believe the Reed-Prentice Corp lathe is chain drive from the motor up to the head stock.
Old 09-22-2010, 08:39:09 PM
Thank you for the info. The big brass tags for the spindle speeds and the thread cutting/feed rates are in good shape. Do you have access to operating manual?
Thanks Hal h.hallford@juno.com
Old 09-23-2010, 01:32:31 PM
I can check and see if the club has one, but I highly doubt it.....
It could be a few weeks or more before I see anyone that would know.
Hopefully someone else can help you there in the mean time, or try an Internet search, Google or otherwise....
Old 09-28-2010, 09:15:48 AM
magneticanomaly magneticanomaly is offline
Try practicalmachinist.com --------antique machiunery sub-forum
Old 09-29-2010, 03:02:21 AM
They are nice machines, so I don't see how you could go wrong if it's in good shape.
Richard W.
Old 09-29-2010, 07:12:18 PM
Thanks! I an looking forward to getting it set up in my home shop.
---------- Post added at 06:12 PM ---------- Previous post was at 06:09 PM ----------
Thank you! I checked and they had the material I wanted
WWII era generator Mike Blauer Generators & Electric Motors General Discussion 3 12-17-2009 08:34:19 PM
Vintage Lathe Lubricants Rex Piekarczyk Machine Shop and Tool Talk 17 04-21-2009 09:32:13 PM
Carb parts for WWII Vintage Homelite Pump MFaragher Farm Antiques and Collectibles 0 04-12-2009 05:50:37 PM
WWII Vintage Homelite Pump Anonymous Small Air Cooled Gasoline Engines 0 04-12-2009 01:04:45 PM
Onan Genset WWII Vintage Dave Hogan Onan Generators 0 05-06-2004 09:51:16 PM
