Twentieth Century Welder-- Help!
this thread has 3 replies and has been viewed 5609 times
Old 09-24-2010, 11:22:32 AM
russell25hp russell25hp is offline
Default Twentieth Century Welder-- Help!
Just acquired a Twentieth Century 180 amp AC welder. It has plug in leads. It has 4 holes in the front which to plug the leads, but no markings as to which goes where. It appears to have a high and low side, according to the dial on the front. Anybody have one of these or know which holes to use? Thanks
Old 09-24-2010, 08:46:23 PM
Heins Heins is offline
Default Re: Twentieth Century Welder-- Help!
The four holes below the dial are starting from the left: first hole is high for the electrode, second is cutting ground only, third is ground, and fourth is low for the electrode. Hopes this helps you out.
Old 09-26-2010, 04:47:47 PM
Dempster Dempster is offline
Is it red, blue or green with dial on the front side or red & silver with dial on the top ? Lincoln Electric bought out Century and may can help with manuals for it. Have a green one with dial on front and it's like the one Heins described above. Low, Med, High and two ground holes. Later red & silver ones were the same but the holes went from top to bottom instead of left to right.
Enter Century welder in the box some manuals are online or contact them for others.
http://www.mylincolnelectric.com/Cat...ualsearch.aspx
Old 09-27-2010, 09:42:21 AM
Thanks, works great!
20th Century Or Not? casesteam12 Steam Stationary Engines, Traction Engines 8 01-05-2008 08:10:33 PM
A century of rest? Engine Whisperer Hit & Miss Gas Engine Discussion 9 11-01-2006 02:31:49 AM
Century Gas Generator Klinger Generators & Electric Motors General Discussion 1 12-26-2004 10:00:20 PM
Century Motor Larryp Generators & Electric Motors General Discussion 2 11-03-2004 08:41:44 PM
Just a century. John Hammink Antique Engine Archives 0 03-10-2002 06:25:15 PM
