What is this? Its from Hammond machinery Builders 1958
this thread has 6 replies and has been viewed 2006 times
Old 09-26-2010, 12:37:31 PM
paulmars paulmars is offline
Default What is this? Its from Hammond machinery Builders 1958
I cant find any info on it, except the patent, here: http://www.freepatentsonline.com/2919522.pdf
tks,
>p
Old 09-26-2010, 03:16:45 PM
xplor xplor is offline
Default Re: What is this? Its from Hammond machinery Builders 1958
A primary object of this invention is the provision of an apparatus for holding and positioning a workpiece with respect to a grinding surface on the grinding wheel of an electrolytic grinding machine.
Old 09-26-2010, 03:52:55 PM
OTTO-Sawyer's Avatar
As near as I can figure it's an adjustable work holding fixture for a surface grinder. Mount it on the electromagnet table and swivel, rotate, pivot, & slide adjust the work piece to the postion or angle you need to gring it at.
With a whole lot of 'legal speak' basically saying that in 5,000 words or more.
I think it would be used for custom grinding step drills, end mills, and other custom shop tooling.
But.... I could be wrong. It could be for grinding electrolytic machine parts.
---------- Post added at 02:52 PM ---------- Previous post was at 02:48 PM ----------
Originally Posted by OTTO-Sawyer View Post
postion or angle you need to gring it at...
Ooops.... Typo..... Should have been the position or angle you need to grind it at.... Not gring it at.
Old 09-26-2010, 04:26:32 PM
except there is nothing to fasten said workpiece too.
Old 09-26-2010, 07:17:42 PM
Try this
http://www.google.com/patents/about?...BAJ&dq=2919522
Old 09-27-2010, 12:27:53 AM
Jim K Jim K is offline
By "Electrolytic" I believe it's a machine that looks like a surface grinder but is an EDM with a graphite wheel.We a couple at one time.The brand was Elox.We never used anything like the device in the patent as we had specific fixtures to do the limited number of tasks the machine was used for
Old 09-27-2010, 08:33:11 PM
Pics: http://s276.photobucket.com/albums/k...ool%20hammond/
Link for model builders Contaucreek Scale Model Engineering 3 09-06-2010 07:24:57 AM
Hello all my fellow builders Boilermaker74 Steam Stationary Engines, Traction Engines 6 12-24-2008 11:37:27 AM
Builders Foundry Lineshaft Frank Y Antique Engine Archives 2 12-17-2002 01:35:48 PM
Builders foundry Frank Y Antique Engine Archives 0 11-16-2002 09:40:47 PM
otto builders plates Bruce Lawson Antique Engine Archives 1 02-06-2002 07:40:14 PM
