Paint Shop
Trying Electrolysis
this thread has 5 replies and has been viewed 2586 times
Old 09-29-2010, 06:07:42 PM
Matthew Sopher Matthew Sopher is offline
Default Trying Electrolysis
Does anybody know the ratio of washing soda per gallon of water to acheive maximum cleaning in a larger tank (i.e. 40 gallons)?
Old 09-29-2010, 06:26:28 PM
Sam Hamilton's Avatar
Sam Hamilton Sam Hamilton is offline
Default Re: Trying electrolysis
I don't think it is too critical. The university chemist who told me to add washing soda to my electrolysis tank indicated that it improves the electrical conductivity of the water. He said to use one regular 2 or 3 pound grocery store box to my tank. I don't know how many gallons it holds but it is 3' x 3' x 3' (a 3 foot cube shipping pallet with the top cut out). I've had great luck with it for years.
The Following User Says Thank You to Sam Hamilton For This Post:
Old 09-29-2010, 07:24:50 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
I have a 100 gal tank and use 2 boxes of Arm & Hammer.
J.I.M.
The Following User Says Thank You to John in Maryland For This Post:
Old 10-02-2010, 10:31:19 AM
Rick Cline Rick Cline is offline
Default Need Help with my Electrolysis Vat
I am new to this fourm, Man the info you guys produce is great.
I built this electrolysis vat and had it up and running with 25 gallons of water 3 cups of Arm & Hammer washing soda, It started to do it thing as soon as I hooked it up. But then after about three ours it stooped (kicked my charger out). Reset everything to start over all it dose is kick out my charger. Can't get any bubbles or water movement at all.
So I drained it cleaned the rods refilled now it dose not do anything (no bubbles) and kicks out my charger. I also tryed different chargers.
I'm at a loss!
Ill try to post a photo of the vat latter.
Any help would be appreciated.
Rick Cline
---------- Post added at 09:31 AM ---------- Previous post was at 09:15 AM ----------
Matthew
I am sorry I did not mean to post under you post. My mistake first time here. Need to pay better attention at what I an doing.
Rick Cline
Old 10-03-2010, 06:49:04 PM
Default Re: Need Help with my Electrolysis Vat
No problem Rick. I finally realized that I did not have enough washing soda for my set up. I've got approx. 40 gallons of water and it took about a box and a quarter (3.5lb. box) to get any good results with my tank.
The Following User Says Thank You to Matthew Sopher For This Post:
Old 10-03-2010, 10:53:45 PM
Shock Shock is offline
Default Re: Trying Electrolysis
Rick, as the process runs, the resistance may go up to the point where it clicks your charger off. Your charger probably cuts off at a certain resistance to protect the battery when it is fully charged. Try changing the water and electrolyte as well as cleaning the rod.
Other than that, just double check all the connections, make sure your clips are touching metal on the part and rod rather than an oxydized surface, which will increase resistance or simply block the current.
Hope that helps,
Grant
The Following User Says Thank You to Shock For This Post:
Electrolysis GarysToys Hit & Miss Gas Engine Discussion 3 03-27-2006 03:53:25 AM
Electrolysis Mike Inglis Antique Engine Archives 9 05-18-2004 08:53:21 PM
Electrolysis Tom Winland Antique Engine Archives 22 10-17-2002 05:09:06 AM
Electrolysis Charlie Allen Antique Engine Archives 6 10-04-2002 02:57:16 PM
Electrolysis ? John Stewart Antique Engine Archives 6 10-03-2002 11:39:00 PM
