Reed Manufacturing Vises
this thread has 9 replies and has been viewed 6188 times
Old 10-01-2010, 10:13:55 AM
Mark Shulaw Mark Shulaw is offline
Default Reed Manufacturing Vises
Hay All,
I am looking for a source for parts for a obsolete vise from Reed Manufacturing of Erie PA. Its a 404 1/2 R They have obsoleted the vise and its parts but I was wondering if there might be someone here who would know of anything that the manufacturer does not. As we all know there always seems to be a part out there, Its just finding it. I'm gonna test the limits of the group on this one I know. Anyone know of a source for parts? I hate to junk such a beast of a vise. I need the heart of the vise, the main nut or the part that the screw threads into is stripped out. The screw threads have a bit of wear but if I can find just the main nut, this vise will serve for years yet. Thanks , Mark
Old 10-01-2010, 10:47:39 AM
rleonard rleonard is offline
Default Re: Reed Manufacturing Vises
Any good machine shop should be able to machine a new one. Although the cost could be more than another vice.
The Following User Says Thank You to rleonard For This Post:
Old 10-01-2010, 11:01:58 AM
Roland Hayes Roland Hayes is offline
It it possible that a nut from another vise might fit with some modifications, or at least be machined down in a lathe as a repair piece to fit and weld into your bored out nut, just a thought.
The Following User Says Thank You to Roland Hayes For This Post:
Old 10-01-2010, 11:36:44 AM
rhkoch rhkoch is offline
That's right, most vises have a standard Acme thread. It should be easy to get a nut with the same thread, and adapt it to your vise.
The Following User Says Thank You to rhkoch For This Post:
Old 10-01-2010, 01:36:37 PM
KHill KHill is offline
I believe you can get acme thread sleeves from McMaster carr.
Bore old treads out from your parts and thread with appropriate threads and thread sleeve to match screw in and pin with locktite on threads and you will have a fix.
Keith
The Following User Says Thank You to KHill For This Post:
Old 10-01-2010, 03:33:48 PM
Pat Barrett Pat Barrett is online now
Might not hurt to try to see if the nut from a pipe wrench fits. It could be welded in place if it did and those are easy to find.
The Following User Says Thank You to Pat Barrett For This Post:
Old 10-01-2010, 07:11:16 PM
Some vises us a "stub acme" thread which the thread depth is not as deep as a regular Acme thread. I have in time past made a new nut and welded it where the old nut was cut off. A picture would help to sort things out and other options may be available.
Richard W.
The Following User Says Thank You to Richard W. For This Post:
Old 10-02-2010, 09:00:11 AM
We are looking into the nuts from currently available Reed vises. None will direct fit. They are similar in appearances. Modifying these is not a task for me since I am not a machinist. Here is what a Reed vise main nut looks like. Mark
Old 10-02-2010, 10:26:06 AM
It seems to me that the tubular nut section of your piece could be simply cut off with a hacksaw and a piece from another vise of similar thread could be cut and welded onto it, another idea is to purchase 2 similar to your leadscrew acme threaded nuts and weld them on to each side of your piece after having cut a section out of each side to allow them space to fit. Your leadscrew would have to be fitted through the middle of the assembly to align all of the parts, this would reduce the complexity of the engineering to a simple welding or brazing job. Also the 2 repair nuts could be set to reduce play in your part worn leadscrew, the repaired piece would then be as strong as the origional as you are only using the welds to prevent the repair nuts from turning. You'll get there, which ever way you decide to try, any chance of a few pictures of the progress, warm regards
Old 10-02-2010, 03:40:25 PM
That looks pretty much like the one repaired for a guy. I took a piece of round stock about the same diameter as the round part on your nut. Drilled it and single pointed a stub acme thread. Then the round part was sawed off and the new nut welded on. (Note we made the threads a little loose to allow for welding shrink/movement.) That was almost 20 years ago and as far as I know it still working for the guy.
Richard W.
Looking to compare notes about post vises. Any collectors? santa claus Blacksmithing and Metallurgy 18 04-12-2012 01:15:21 PM
How come? (Reed Valves) Rex Wellendorf Small Air Cooled Gasoline Engines 8 09-05-2010 09:35:24 PM
Dave Reed John Davis Hit & Miss Gas Engine Discussion 2 12-29-2006 05:34:06 PM
Dave Reed was right! Kevin O. Pulver Antique Engine Archives 4 08-17-2004 10:44:08 PM
