Paint Shop
Need Help with my Electrolysis Vat
this thread has 6 replies and has been viewed 2954 times
Old 10-02-2010, 10:20:40 AM
Rick Cline Rick Cline is offline
Default Need Help with my Electrolysis Vat
I am new to this fourm, Man the info you guys produce is great.
I built this electrolysis vat and had it up and running with 25 gallons of water 3 cups of Arm & Hammer washing soda, It started to do it thing as soon as I hooked it up. But then after about three ours it stooped (kicked my charger out). Reset everything to start over all it dose is kick out my charger. Can't get any bubbles or water movement at all.
So I drained it cleaned the rods refilled now it dose not do anything (no bubbles) and kicks out my charger. I also tryed different chargers.
I'm at a loss!
Ill try to post a photo of the vat latter.
Any help would be appreciated.
Rick Cline
Old 10-02-2010, 12:07:23 PM
peterR peterR is offline
Default Re: Need Help with my Electrolysis Vat
Does your set up draw too much current so the chargers are tripping. Try a weaker solution or smaller electrodes or only partially immerse the subject metal.
Peter
The Following User Says Thank You to peterR For This Post:
Old 10-02-2010, 07:20:50 PM
Here are two photo's of my vat. Also I put my meter in the water it reads 5 amps. With no water action like I did the first time I used it.
Rick Cline
ID:	89102   Click image for larger version
Old 10-05-2010, 09:39:10 PM
I got this thing working. Only using 4 electrodes 2 on each end and 2 in the middle. Over load due too to many electrodes.
The Following User Says Thank You to Rick Cline For This Post:
Old 10-05-2010, 09:48:49 PM
Skidmore's Avatar
Skidmore Skidmore is offline
Tell us what you used to make this, it looks great . I have been wanting to build one myself. hope it works as good as it looks. thanks Skidmore
Old 10-11-2010, 10:20:32 PM
The tub came from a Mini Mart. It was a cooler that they put pop and water in. They was scraping it now it is a Electrolysis Vat. I had a few problems at first but got it working now.
Rick
Old 10-12-2010, 09:43:41 AM
Elden DuRand's Avatar
Rick:
What you could do to lower the current is to hook up a paralleled batch of 12 volt brakelight bulbs in series with the charger. They will act as a ballast resistor.
Take care - Elden
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Trying Electrolysis Matthew Sopher Paint Shop 5 10-03-2010 10:53:45 PM
Electrolysis? jerryreggie Hit & Miss Gas Engine Discussion 1 03-04-2009 09:28:19 PM
Electrolysis Vic Pankoski Antique Engine Archives 15 07-12-2003 11:07:15 PM
electrolysis Fhartman Antique Engine Archives 0 12-14-2002 06:31:52 PM
Electrolysis Tom Winland Antique Engine Archives 22 10-17-2002 05:09:06 AM
