Rocker arm resurfacing
this thread has 2 replies and has been viewed 3930 times
Old 10-28-2010, 07:32:23 PM
Paul Roidt Paul Roidt is offline
Default Rocker arm resurfacing
Looking for a rocker arm resurfacing attachment for a valve grinder.
Or pictures of one with dimensions so I can build one.
I have a black and decker valve grinder.
Paul
Old 10-30-2010, 07:21:03 PM
Heins Heins is offline
Default Re: Rocker arm resurfacing
If no one has helped you, let me know and I will e mail pictures of my rocker arm refacer on my valve grinder.
Old 11-27-2010, 11:52:58 AM
Dave Richards Dave Richards is offline
My Kwick-Way has an attachment that is nothing more than a slotted, adjustable bracket with a perfictly vertical post a little in front of and off to the side of the stem tip refacing wheel (cupped) on the back end of the machine. There are a pair of centering cones for the rocker to go between that you drop over the pin. You hold the rocker down and with a little pressure against the cupped wheel, cycle the slide a half a dozen times over the rocker tip and it follows the radius around on the tip really well. It works better than you would think.
Dave Richards
The Following User Says Thank You to Dave Richards For This Post:
Sioux model 40V505 valve resurfacing machine lbacker Machine Shop and Tool Talk 0 09-26-2010 04:53:03 PM
10-20 rocker arm EngineBob Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 11-26-2009 04:57:39 PM
LB rocker arm Walt in Jaxn Tn. Antique Engine Archives 2 09-18-2004 10:10:53 PM
Delco rocker arm Mike Semanoff Delco and other Low Voltage DC Light Plants 2 12-09-2000 01:47:21 PM
Rocker Arm Robert Smales Antique Engine Archives 0 09-21-1999 06:07:33 AM
